WiFi Disconnect When USB Dongle Attached for Wireless Headset
JasonPCG
I have been all over the internet looking for a solution, and I am out of search terms.
I uninstalled and reinstalled drivers for both the NIC and the Headset.
I checked the firmware on my WiFi router.
I changed the band on my WiFi router.
I checked for Windows 7 Updates, Vid Card, Driver updates of every type.
I'm out of ideas.
I have a wireless headset with a dongle. This expensive piece of garbage* has a mic on it. I use Ventrilo for some online games. I also have a Wireless-N network adapter installed in my computer.
I do not always use the headset, and as a result I plug in or unplug the headset dongle as necessary. For no apparent reason the mic on my headset fails to work many times when I turn on the headset, regardless of the fact that the dongle was never unplugged, but I powered off the headset to use external speakers. As a result i have to disconnect the dongle for several seconds and reconnect it, then pair it with the headset again (headset and dongle came together) to attempt to get my mic to work.
This is a minor nuisance to me. The major issue is that I am completely disconnected from my WiFi connection for ~5 minutes until I close all the programs that were using the internet and attempt to reconnect, typically I have to let windows 7 troubleshooter fix the connection (otherwise i'm in the magical command prompt screen /ipconfiging it) or it will get stuck on connecting and do absolutely nothing.
I am at the end of the rope here, and I have no idea what the issue is. I thought altering the band on my WiFi router would fix it, or a firmware or driver update for any of the three (Router, Headset, NIC) pieces would fix it, but all of my work over the past week has been in vain.
Please, if you have any ideas I'm open to suggestions, as I've run out of search terms for Google to attempt to find an answer somewhere out there for my problem.
Below is my DXDIAG file if this helps at all...
System Information
Time of this report: 7/9/2010, 00:58:55
Operating System: Windows 7 Professional 32-bit (6.1, Build 7600) (7600.win7_gdr.100226-1909)
Language: English (Regional Setting: English)
System Manufacturer: NVIDIA
System Model: 132-CK-NF78
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: Intel(R) Core(TM)2 Duo CPU E6850 @ 3.00GHz (2 CPUs), ~3.0GHz
Memory: 4096MB RAM
Available OS Memory: 2814MB RAM
Page File: 1902MB used, 3724MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7600.16385 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Sound Tab 3: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce GTX 275
Chip type: GeForce GTX 275
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_05E6&SUBSYS_0E0619F1&REV_A1
Display Memory: 2032 MB
Dedicated Memory: 881 MB
Shared Memory: 1151 MB
Current Mode: 1920 x 1200 (32 bit) (59Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: DELL 2407WFP
Monitor Id: DELA017
Native Mode: 1920 x 1200(p) (59.950Hz)
Output Type: DVI
Driver Name: nvd3dum.dll,nvwgf2um.dll,nvwgf2um.dll
Driver File Version: 8.17.0011.9745 (English)
Driver Version: 8.17.11.9745
DDI Version: 10
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 4/3/2010 18:55:31, 9386600 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71E3E-46A6-11CF-505C-0D2E1FC2C535}
Vendor ID: 0x10DE
Device ID: 0x05E6
SubSys ID: 0x0E0619F1
Revision ID: 0x00A1
Driver Strong Name: oem24.inf:NVIDIA_SetA_Devices.NTx86.6.1:Section003:8.17.11.9745:pci\ven_10de&dev_05e6
Rank Of Driver: 00E62001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Speakers (Logitech Speaker Lapdesk N700)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: USB\VID_046D&PID_0A1A&REV_0100&MI_00
Manufacturer ID: 65535
Product ID: 65535
Type: WDM
Driver Name: USBAUDIO.sys
Driver Version: 6.01.7600.16385 (English)
WHQL Logo'd: Yes
Date and Size: 7/13/2009 19:51:23, 80640 bytes
Other Files:
Driver Provider: Microsoft
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Digital Audio (HDMI) (High Definition Audio Device)
Default Sound Playback: No
Default Voice Playback: No
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_10DE0175&REV_1001
Manufacturer ID: 1
Product ID: 65535
Type: WDM
Driver Name: HdAudio.sys
WHQL Logo'd: Yes
Date and Size: 7/13/2009 19:51:47, 304128 bytes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Description: Digital Audio (S/PDIF) (High Definition Audio Device)
Manufacturer ID: 1
Product ID: 65535
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x1
Format Flags: 0xFFFFF
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Logitech Speaker Lapdesk N700
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0x0A1A
FF Driver: n/a
Device Name: USB Receiver
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC517
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: American Power Conversion USB UPS
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x051D, 0x0002
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x10DE, 0x036C
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 10/24/2009 00:00:07, 258560 bytes
| Driver: usbd.sys, 7/13/2009 19:51:05, 5888 bytes
+-+ American Power Conversion USB UPS
| | Matching Device ID: usb\vid_051d&pid_0002
| | Service: HidUsb
| | Driver: hidusb.sys, 7/13/2009 19:51:04, 24064 bytes
| | Driver: hidclass.sys, 7/13/2009 19:51:01, 55808 bytes
| | Driver: hidparse.sys, 7/13/2009 19:51:00, 25728 bytes
+-+ USB Input Device
| | Vendor/Product ID: 0x046D, 0xC051
| | Matching Device ID: generic_hid_device
| | Service: HidUsb
| +-+ HID-compliant mouse
| | | Matching Device ID: hid_device_system_mouse
| | | Service: mouhid
| | | Driver: mouhid.sys, 7/13/2009 19:45:08, 26112 bytes
| | | Driver: mouclass.sys, 7/13/2009 21:20:44, 41552 bytes
Gameport Devices
PS/2 Devices
+ HID Keyboard Device
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 7/13/2009 19:45:09, 28160 bytes
| Driver: kbdclass.sys, 7/13/2009 21:20:36, 42576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: i8042prt.sys, 7/13/2009 19:11:24, 80896 bytes
| Service: mouhid
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
| Driver: termdd.sys, 7/13/2009 21:19:10, 51776 bytes
| Driver: sermouse.sys, 7/13/2009 19:45:08, 19968 bytes
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 169.4 GB
Total Space: 476.9 GB
File System: NTFS
Model: WDC WD50 00KS-00MNB0 SCSI Disk Device
Drive: D:
Free Space: 261.2 GB
Total Space: 476.8 GB
File System: NTFS
Drive: G:
Model: ELBY CLONEDRIVE SCSI CdRom Device
Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7600.16385 (English), 7/13/2009 19:11:26, 108544 bytes
Drive: F:
Model: Memorex 16X DVD-ROM AJiA ATA Device
Drive: E:
Model: TSSTcorp CDDVDW SH-S202N ATA Device
System Devices
Name: PCI Express standard Downstream Switch Port
Device ID: PCI\VEN_10DE&DEV_05B1&SUBSYS_00000000&REV_A2\5&34045AFB&0&000018
Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.01.7600.16385 (English), 7/13/2009 21:20:45, 153680 bytes
Name: PCI standard RAM Controller
Device ID: PCI\VEN_10DE&DEV_03B2&SUBSYS_C55E10DE&REV_A1\3&2411E6FE&1&0D
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03AA&SUBSYS_C55E10DE&REV_A1\3&2411E6FE&1&02
Driver: n/a
Name: NVIDIA nForce 10/100/1000 Mbps Ethernet #2
Device ID: PCI\VEN_10DE&DEV_0373&SUBSYS_C55E10DE&REV_A3\3&2411E6FE&1&90
Driver: n/a
Name: NVIDIA nForce PCI System Management
Device ID: PCI\VEN_10DE&DEV_0368&SUBSYS_C55E10DE&REV_A3\3&2411E6FE&1&51
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03BC&SUBSYS_C55E10DE&REV_A1\3&2411E6FE&1&11
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03B1&SUBSYS_C55E10DE&REV_A1\3&2411E6FE&1&0C
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03A9&SUBSYS_C55E10DE&REV_A1\3&2411E6FE&1&03
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0373&SUBSYS_C55E10DE&REV_A3\3&2411E6FE&1&88
Driver: n/a
Name: PCI standard ISA bridge
Device ID: PCI\VEN_10DE&DEV_0360&SUBSYS_C55E10DE&REV_A3\3&2411E6FE&1&50
Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/13/2009 21:20:43, 13888 bytes
Device ID: PCI\VEN_10DE&DEV_03BA&SUBSYS_C55E10DE&REV_A1\3&2411E6FE&1&12
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03B0&SUBSYS_C55E10DE&REV_A1\3&2411E6FE&1&0B
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03A8&SUBSYS_C55E10DE&REV_A2\3&2411E6FE&1&05
Driver: n/a
Name: High Definition Audio Controller
Device ID: PCI\VEN_10DE&DEV_0371&SUBSYS_10DE0175&REV_A2\3&2411E6FE&1&79
Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.01.7600.16385 (English), 7/13/2009 19:50:56, 108544 bytes
Name: Texas Instruments 1394 OHCI Compliant Host Controller
Device ID: PCI\VEN_104C&DEV_8023&SUBSYS_C55E10DE&REV_00\4&36AC3632&0&3878
Driver: C:\Windows\system32\DRIVERS\1394ohci.sys, 6.01.7600.16385 (English), 7/13/2009 19:52:00, 163328 bytes
Name: PCI Express standard Root Port
Device ID: PCI\VEN_10DE&DEV_03B7&SUBSYS_0C5510DE&REV_A1\3&2411E6FE&1&18
Device ID: PCI\VEN_10DE&DEV_03AF&SUBSYS_C55E10DE&REV_A1\3&2411E6FE&1&0A
Driver: n/a
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_10DE&DEV_03A1&SUBSYS_C55E10DE&REV_A2\3&2411E6FE&1&00
Driver: n/a
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_10DE&DEV_0370&SUBSYS_CB8410DE&REV_A2\3&2411E6FE&1&78
Name: RangeMax(tm) NEXT Wireless Adapter WN311B
Device ID: PCI\VEN_14E4&DEV_4329&SUBSYS_7D001385&REV_01\4&36AC3632&0&4878
Driver: C:\Windows\system32\DRIVERS\WN311B.SYS, 4.170.0064.0051 (English), 3/27/2008 16:04:10, 1187320 bytes
Device ID: PCI\VEN_10DE&DEV_03B6&SUBSYS_C55E10DE&REV_A1\3&2411E6FE&1&10
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03AE&SUBSYS_C55E10DE&REV_A1\3&2411E6FE&1&09
Driver: n/a
Name: NVIDIA nForce Serial ATA Controller
Device ID: PCI\VEN_10DE&DEV_037F&SUBSYS_C55E10DE&REV_A3\3&2411E6FE&1&72
Driver: C:\Windows\system32\DRIVERS\nvstor32.sys, 11.01.0000.0033 (English), 8/4/2009 16:43:40, 213024 bytes
Driver: C:\Windows\system32\nvraidco.dll, 11.01.0000.0033 (English), 8/4/2009 16:43:40, 372768 bytes
Driver: C:\Windows\system32\nvraiins.dll, 11.01.0000.0033 (English), 8/4/2009 16:43:40, 372768 bytes
Driver: C:\Windows\system32\NvRCoDa.dll, 11.01.0000.0033 (Danish), 8/4/2009 16:43:42, 17440 bytes
Driver: C:\Windows\system32\NvRCoDe.dll, 11.01.0000.0033 (German), 8/4/2009 16:43:44, 17952 bytes
Driver: C:\Windows\system32\NvRCoEng.dll, 11.01.0000.0033 (English), 8/4/2009 16:43:44, 16928 bytes
Driver: C:\Windows\system32\NvRCoENU.dll, 11.01.0000.0033 (English), 8/4/2009 16:43:46, 16928 bytes
Driver: C:\Windows\system32\NvRCoEs.dll, 11.01.0000.0033 (Spanish), 8/4/2009 16:43:48, 17952 bytes
Driver: C:\Windows\system32\NvRCoEsm.dll, 11.01.0000.0033 (Spanish), 8/4/2009 16:43:48, 17952 bytes
Driver: C:\Windows\system32\NvRCoFi.dll, 11.01.0000.0033 (Finnish), 8/4/2009 16:43:50, 17440 bytes
Driver: C:\Windows\system32\NvRCoFr.dll, 11.01.0000.0033 (French), 8/4/2009 16:43:52, 17952 bytes
Driver: C:\Windows\system32\NvRCoIt.dll, 11.01.0000.0033 (Italian), 8/4/2009 16:43:52, 17952 bytes
Driver: C:\Windows\system32\NvRCoJa.dll, 11.01.0000.0033 (Japanese), 8/4/2009 16:43:54, 15392 bytes
Driver: C:\Windows\system32\NvRCoKo.dll, 11.01.0000.0033 (Korean), 8/4/2009 16:43:54, 15392 bytes
Driver: C:\Windows\system32\NvRCoNl.dll, 11.01.0000.0033 (Dutch), 8/4/2009 16:43:56, 17440 bytes
Driver: C:\Windows\system32\NvRCoNo.dll, 11.01.0000.0033 (Norwegian (Bokmål)), 8/4/2009 16:43:58, 17440 bytes
Driver: C:\Windows\system32\NvRCoPtb.dll, 11.01.0000.0033 (Portuguese), 8/4/2009 16:44:00, 17952 bytes
Driver: C:\Windows\system32\NvRCoRu.dll, 11.01.0000.0033 (Russian), 8/4/2009 16:44:02, 17440 bytes
Driver: C:\Windows\system32\NvRCoSv.dll, 11.01.0000.0033 (Swedish), 8/4/2009 16:44:06, 17440 bytes
Driver: C:\Windows\system32\NvRCoZhc.dll, 11.01.0000.0033 (Chinese (Simplified)), 8/4/2009 16:44:08, 14880 bytes
Driver: C:\Windows\system32\NvRCoZht.dll, 11.01.0000.0033 (Chinese (Traditional)), 8/4/2009 16:44:10, 14880 bytes
Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_10DE&DEV_036E&SUBSYS_C55E10DE&REV_A1\3&2411E6FE&1&68
Driver: C:\Windows\system32\DRIVERS\pciide.sys, 6.01.7600.16385 (English), 7/13/2009 21:20:45, 12368 bytes
Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.01.7600.16385 (English), 7/13/2009 21:19:03, 42560 bytes
Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.01.7600.16385 (English), 7/13/2009 21:26:15, 21584 bytes
Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.01.7600.16385 (English), 7/13/2009 21:26:15, 133200 bytes
Name: NVIDIA GeForce GTX 275
Device ID: PCI\VEN_10DE&DEV_05E6&SUBSYS_0E0619F1&REV_A1\6&689986E&0&00000018
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_disp.inf_x86_neutral_cd684a90409bd8fa\NvCplSetupEng.exe, 14.00.0000.0162 (English), 4/3/2010 18:55:31, 18344184 bytes
Driver: C:\Windows\system32\DRIVERS\nvBridge.kmd, 8.17.0011.9745 (English), 4/3/2010 18:55:31, 10920 bytes
Driver: C:\Windows\system32\DRIVERS\nvlddmkm.sys, 8.17.0011.9745 (English), 4/3/2010 18:55:31, 11573800 bytes
Driver: C:\Windows\system32\OpenCL.dll, 1.00.0000.0000 (English), 4/3/2010 18:55:31, 56424 bytes
Driver: C:\Windows\system32\dpinst.exe, 2.01.0000.0000 (English), 4/3/2010 18:55:31, 795104 bytes
Driver: C:\Windows\system32\nvapi.dll, 8.17.0011.9745 (English), 4/3/2010 18:55:31, 1296488 bytes
Driver: C:\Windows\system32\nvcompiler.dll, 8.17.0011.9745 (English), 4/3/2010 18:55:31, 11647592 bytes
Driver: C:\Windows\system32\nvcuda.dll, 8.17.0011.9745 (English), 4/3/2010 18:55:31, 4029544 bytes
Driver: C:\Windows\system32\nvcuvenc.dll, 8.17.0011.9745 (English), 4/3/2010 18:55:31, 2646632 bytes
Driver: C:\Windows\system32\nvcuvid.dll, 8.17.0011.9745 (English), 4/3/2010 18:55:31, 2009704 bytes
Driver: C:\Windows\system32\nvd3dum.dll, 8.17.0011.9745 (English), 4/3/2010 18:55:31, 9386600 bytes
Driver: C:\Windows\system32\nvdecodemft.dll, 8.17.0011.9745 (English), 4/3/2010 18:55:31, 316008 bytes
Driver: C:\Windows\system32\nvencodemft.dll, 8.17.0011.9745 (English), 4/3/2010 18:55:31, 2907752 bytes
Driver: C:\Windows\system32\nvinfo.pb, 4/3/2010 18:55:31, 7772 bytes
Driver: C:\Windows\system32\nvoglv32.dll, 8.17.0011.9745 (English), 4/3/2010 18:55:31, 15227496 bytes
Driver: C:\Windows\system32\nvwgf2um.dll, 8.17.0011.9745 (English), 4/3/2010 18:55:31, 4503144 bytes
Driver: C:\Program Files\NVIDIA Corporation\Uninstall\nvdisp.nvu, 4/3/2010 18:55:31, 22936 bytes
Driver: C:\Program Files\NVIDIA Corporation\Uninstall\nvudisp.exe, 1.10.0059.0037 (English), 4/3/2010 18:55:31, 600680 bytes
Driver: C:\Windows\system32\nvcod.dll, 1.09.0014.0099 (English), 4/3/2010 18:55:31, 227944 bytes
Driver: C:\Windows\system32\nvcod1914.dll, 1.09.0014.0099 (English), 4/3/2010 18:55:31, 227944 bytes
Device ID: PCI\VEN_10DE&DEV_03B5&SUBSYS_C55E10DE&REV_A1\3&2411E6FE&1&06
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03AD&SUBSYS_C55E10DE&REV_A1\3&2411E6FE&1&08
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_037F&SUBSYS_C55E10DE&REV_A3\3&2411E6FE&1&71
Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_10DE&DEV_036D&SUBSYS_C55E10DE&REV_A2\3&2411E6FE&1&59
Driver: C:\Windows\system32\drivers\usbehci.sys, 6.01.7600.16445 (English), 10/23/2009 23:58:55, 41984 bytes
Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7600.16385 (English), 7/13/2009 19:51:15, 284160 bytes
Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7600.16445 (English), 10/24/2009 00:00:07, 258560 bytes
Name: PCI Express standard Upstream Switch Port
Device ID: PCI\VEN_10DE&DEV_05B1&SUBSYS_C55E10DE&REV_A2\4&6BB9499&0&0018
Device ID: PCI\VEN_10DE&DEV_03B4&SUBSYS_C55E10DE&REV_A1\3&2411E6FE&1&07
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03AC&SUBSYS_C55E10DE&REV_A1\3&2411E6FE&1&01
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_037F&SUBSYS_C55E10DE&REV_A3\3&2411E6FE&1&70
Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_10DE&DEV_036C&SUBSYS_C55E10DE&REV_A1\3&2411E6FE&1&58
Driver: C:\Windows\system32\drivers\usbohci.sys, 6.01.7600.16385 (English), 7/13/2009 19:51:14, 20480 bytes
Device ID: PCI\VEN_10DE&DEV_05B1&SUBSYS_00000000&REV_A2\5&34045AFB&0&100018
Device ID: PCI\VEN_10DE&DEV_03B3&SUBSYS_C55E10DE&REV_A1\3&2411E6FE&1&0E
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03AB&SUBSYS_C55E10DE&REV_A1\3&2411E6FE&1&04
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0376&SUBSYS_000010DE&REV_A3\3&2411E6FE&1&98
Device ID: PCI\VEN_10DE&DEV_0369&SUBSYS_C55E10DE&REV_A2\3&2411E6FE&1&48
Driver: n/a
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7600.16385
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7600.16385
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7600.16385
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7600.16385
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7600.16385
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
ffdshow Video Decoder,0xff800001,2,1,ffdshow.ax,1.00.0007.3064
ffdshow raw video filter,0x00200000,2,1,ffdshow.ax,1.00.0007.3064
ffdshow Audio Decoder,0x3fffffff,1,1,ffdshow.ax,1.00.0007.3064
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7600.16385
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7600.16490
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7600.16385
DivX AAC Decoder,0x00800000,1,1,daac.ax,7.01.0000.0010
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7600.16385
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7600.16490
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7600.16490
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7600.16385
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
Creative Recording Wav_Asio Filter,0x00400000,0,1,AudioRec.ax,1.00.0002.0000
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7600.16590
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7600.16385
Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7600.16385
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7600.16490
CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.01.7600.16385
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7600.16490
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7600.16385
MPC - MPEG-2 Video Decoder (Gabest),0x00500001,1,1,Mpeg2DecFilter.ax,1.03.1264.0000
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7600.16590
AAC Parser,0x00400000,1,1,aac_parser.ax,1.01.0000.0000
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7600.16385
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7600.16385
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7600.16385
DivX MKV Demux (unrestricted),0x00200000,0,1,DMFSource.ax,1.00.0002.0006
MPC - FLV Splitter (Gabest),0x00600000,1,1,FLVSplitter.ax,1.03.1264.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7600.16490
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7600.16490
WavPack Audio Decoder,0x00600000,1,1,WavPackDSDecoder.ax,1.01.0000.0484
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7600.16385
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7600.16490
Haali Media Splitter,0x00800001,0,1,splitter.ax,1.09.0042.0001
Haali Media Splitter (AR),0x00400000,1,1,splitter.ax,1.09.0042.0001
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7600.16385
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7600.16490
CoreAAC Audio Decoder,0x00800000,1,1,CoreAAC.ax,1.01.0000.0642
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7600.16490
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7600.16385
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7600.16385
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7600.16490
DivX H.264 Decoder,0x00800000,1,1,DivXDecH264.ax,9.00.0001.0021
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7600.16490
Haali Video Renderer,0x00200000,1,0,dxr.dll,
DivX Decoder Filter,0x00800000,1,1,DivXDec.ax,7.01.0001.0014
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7600.16385
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7600.16385
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7600.16385
File writer,0x00200000,1,0,qcap.dll,6.06.7600.16385
iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7600.16385
iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7600.16385
Haali Simple Media Splitter,0x00200000,0,1,splitter.ax,1.09.0042.0001
DirectVobSub,0x00200000,2,1,VSFilter.dll,1.03.1264.0000
DirectVobSub (auto-loading version),0x00800002,2,1,VSFilter.dll,1.03.1264.0000
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7600.16385
Microsoft TV Subtitles Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7600.16385
Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7600.16385
Haali Matroska Muxer,0x00200000,1,0,splitter.ax,1.09.0042.0001
DivX MKV Demux,0x00600000,0,1,DMFSource.ax,1.00.0002.0006
AVI Draw,0x00600064,9,1,quartz.dll,6.06.7600.16490
RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7600.16385
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7600.16385
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7600.16590
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7600.16385
ffdshow Audio Processor,0x00200000,1,1,ffdshow.ax,1.00.0007.3064
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7600.16385
Null Renderer,0x00200000,1,0,qedit.dll,6.06.7600.16385
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7600.16385
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7600.16385
MPC - FLV Source (Gabest),0x00600000,0,0,FLVSplitter.ax,1.03.1264.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7600.16385
Smart Tee,0x00200000,1,2,qcap.dll,6.06.7600.16385
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7600.16385
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7600.16490
NetBridge,0x00200000,2,0,netbridge.dll,6.01.7600.16385
DScaler Audio Decoder,0x00800000,1,1,MpegAudio.dll,0.00.0006.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7600.16490
Wave Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
File stream renderer,0x00400000,1,1,quartz.dll,6.06.7600.16490
WavPack Audio Splitter,0x00600000,1,1,WavPackDSSplitter.ax,1.01.0000.0323
ffdshow subtitles filter,0x00200000,2,1,ffdshow.ax,1.00.0007.3064
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7600.16385
AVI Mux,0x00200000,1,0,qcap.dll,6.06.7600.16385
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7600.16490
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7600.16490
File Source (URL),0x00400000,0,1,quartz.dll,6.06.7600.16490
Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.7600.16385
AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
Haali Video Sink,0x00200000,1,0,splitter.ax,1.09.0042.0001
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7600.16385
DScaler Mpeg2 Video Decoder,0x00800000,1,1,MpegVideo.dll,0.00.0006.0000
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7600.16385
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7600.16385
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7600.16490
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7600.16385
ffdshow video encoder,0x00100000,1,1,ffdshow.ax,1.00.0007.3064
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7600.16490
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7600.16385
DivX 6.9.2 Codec (2 Logical CPUs),0x00200000,1,1,qcap.dll,6.06.7600.16385
ffdshow Video Codec,0x00200000,1,1,qcap.dll,6.06.7600.16385
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7600.16385
Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7600.16385
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7600.16385
DivX 6.9.2 YV12 Decoder,0x00200000,1,1,qcap.dll,6.06.7600.16385
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7600.16490
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7600.16490
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7600.16490
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7600.16490
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7600.16490
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7600.16490
Audio Capture Sources:
Digital Audio (S/PDIF) (High De,0x00200000,0,0,qcap.dll,6.06.7600.16385
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7600.16590
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7600.16590
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7600.16590
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7600.16490
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7600.16490
WDM Streaming Capture Devices:
HD Audio Digital in,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
WDM Streaming Rendering Devices:
HD Audio HDMI out,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
HD Audio SPDIF out,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
Logitech Speaker Lapdesk N700,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7600.16590
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7600.16385
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7600.16385
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7600.16385
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7600.16385
PTFilter,0x00200000,0,0,EncDec.dll,6.06.7600.16385
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7600.16385
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (Logitech Speaker Lapd,0x00200000,1,0,quartz.dll,6.06.7600.16490
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7600.16490
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7600.16490
Digital Audio (HDMI) (High Defi,0x00200000,1,0,quartz.dll,6.06.7600.16490
Digital Audio (S/PDIF) (High De,0x00200000,1,0,quartz.dll,6.06.7600.16490
DirectSound: Digital Audio (HDMI) (High Definition Audio Device),0x00200000,1,0,quartz.dll,6.06.7600.16490
DirectSound: Digital Audio (S/PDIF) (High Definition Audio Device),0x00200000,1,0,quartz.dll,6.06.7600.16490
DirectSound: Speakers (Logitech Speaker Lapdesk N700),0x00200000,1,0,quartz.dll,6.06.7600.16490
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
corkyg
Elite Member | Peripherals
27,370
239
TMI! Just a thought. Can you connect a USG powered hub to the computer, and then connect the headest to the hub?
Intexity
299
when doing uninstalls, its a good idea to run ccleaner before reinstalling. if there is a left over issue in the registry, it will clean it. i should get paid for pimping this program, but it is truly great tool.
Devilpapaya
First off, thanks for the wall of text.
Few questions, when you say disconnected from the wireless router, do you mean windows doesn't see any connections, or you can see the connection but can't connect or if you can connect, can't browse any web pages.
At any rate, my first suggestion would be to reset the connection and the tcp/ip stack. Run the following commands from command prompt.
netsh winsock reset (resets windows socket)
netsh int ip reset (resets tcp/ip stack)
(optionally) ipconfig /flushdns (clears dns cache and arp table)
Windows will tell you to restart your computer (wait until you've run all commands), do so and see if you continue to have the problem. This is kinda just a generic fix for networking problems, for better response:
1) When does the wireless-n connection drop? When you attach the dongle or when the dongle stops working?
2) What type of wireless does the headset use; bluetooth or something else?
3) question at the top
4) What brand/model is the headset/wireless NIC, and have you tried googling to see if this is a common problem?
JasonPCG
Sorry, most of the time I notice people need a lot more information so I'm trying to cover all of my bases.
I've come to the conclusion that this is more of a driver/windows issue than an interference issue.
>>The dongle stops working only when I unplug it. The headset works fine, but the mic stops working on it's own and I have to unplug it for about five minutes and plug it back in to get the mic active again.
The internet connection drops at first, then (not always) it looks like the connection disappears. The REALLY crazy part is 2 secure networks drop (WPA) and one unsecure (neighbors) connection continues to show up.
This doesn't always happen, but it was very noticeable last night where I had to do a reboot to get it fixed.
Headset is a Creative Labs GH0100A World of Warcraft wireless gaming headset. I believe it is a bluetooth connection, since there is a short period of time while it 'pairs' with the headset and if it has difficulty you can click the connect button on the side to force pairing again.
I tried a hub to get the dongle away from the wifi nic in hopes there was only some minor interference. It was on the end of a five foot cable and well away from the NIC.
Yeah, I've been working on this for about a week. I cannot figure out what I'm doing wrong. I've googled (model/name/wireless headset) (disconnects) (wireless/wifi) (windows 7), checked the support page, looked in KB's...I'm really stumped.
Thanks everyone who is checking this out, and sorry for the initial info dump. :)
Devilpapaya
Do you notice any change in signal strength with these other networks when your network disappears? How do these other networks compare to your own, are they on the same band(a,b,g,n) / channel(1-11) / stregth(bars, or preferably a db #) / Authentication type (wep, wpa, etc). Also how far away from your computer is your wireless router?
Also you mention that your wireless NIC is n-band, is it actually connected to an n-band network (is your router broadcasting n-band) or are you connected to a b/g network. This is actually pretty critical:
If the issue is the bluetooth headset (looked it up, looks bluetooth if I'm looking at the right one) and your card are broadcasting on the same band then there could be interference issues. Bothblue tooth and wireles b/g bands use the 2.4 Ghz spectrum. So if you're operating on a b/g network the issue of interference while the bluetooth devices broadcast to sync with each other could be very real (quick research show some scattered complaints about this, not necessarily with this device, but with bluetooth in general). However, if you're operating on an n-band network, the issue of interference is less likely, as n-band networks operate (i think) on a 5 Ghz spectrum.
JasonPCG
The other two networks are G. Mine is N. According to my software everything is on the 5ghz spectrum. I also have a laptop that runs on it wireless n. The router is probably 25 feet away and is in the upstairs part of the house.
The signal seems to stay relatively weak...if it exists at all. Both neighbors houses are probably at maximum distance and I am surprised I pick them up at all.
