Wifi Antenna Suggestions
Loafers
I use a USB Wifi Adapter and the reception is lacking in my new room. Desperate, I am now considering a PCI + External Antenna setup. There are many options here, but I'd like some suggestions.
Right now TP-Link's parabolic dish looks appealing, but have no clue how I would mount it indoors. Do they have tripod mounts for this sort of stuff?
A more practical and portable option would probably be a yagi, but the gain is lower and frankly, there are so many to choose from I have no clue what to look for besides db.
Indoor use and no bigger than 2 feet. Any suggestions appreciated.
Playing with Antenna indoor usually does not yield significant improvement signal wise.
Better off to get a second Wireless Router, lay one cable to a good spot in the hallway toward the new room and install the second Wireless Router configured as an Access Point.
Using Access Points or Wireless Cable/DSL Routers as a Switch with an Access Point - http://www.ezlan.net/router_AP.html
Unfortunately, I am a tenant so modifying anything like that wouldn't be allowed 🙁
Also, why would an antenna indoor not yield a better signal?
