Im pretty new to wifi networks, all your ideas are valuable 🙂
[i have internet connection to my main pc through a wired 4port LAN router ]
I'm looking for a cheap wifi adapter to be used for following (range is not that important, i'll use it inside the room and v closer. speed wise 54mbps seems enough too):
~ network with a mobile phone (Nokia) for file transfer and to surf internet through the phone
~ network with a laptop for file transfer and to surf internet through the laptop
1. so a normal cheap adapter is enough, right ?
2. are all adapters can be used as virtual AP with softwares ?
3. is there any plus point getting a PCI (not PCI exp) wifi card over a USB adapter (with external anternna connector) or vice versa ?
4. is any of below are not upto the job ?
http://cgi.ebay.com/USB-Wirele...1%7C293%3A1%7C294%3A50
or
http://www.dealextreme.com/details.dx/sku.24886
http://www.dealextreme.com/details.dx/sku.12782
(no newegg or etc for me as im from srilanka. have to do with this )
Thanks, all the help is highly regarded.
or
