pcslookout
The new Wifi 7 routers.
What are you looking for in WiFi 7 that you don't get in WiFi 6?
For most people AC is still plenty good. Internet speeds in your home are the bottleneck, not wireless.
While you are absolutely correct that 5GHz is more likely the give you a good connection in an urban apartment/condo, the reason isn't really what you think. 5GHz has a much harder time penetrating objects like walls/ceilings/floors. As a result, the signals from one apartment/condo do not penetrate as well into an adjacent unit. This results in your router and wireless devices not seeing the crosstalk from the other nearby networks as much, giving you better performance because really only 1 radio can transmit at one time on a channel without messages becoming garbled and a collision occurring resulting in all the devices going into collision recovery protocol.Personally, I am not actually clear yet which Wifi 7 features will be the most useful.
"most people" seems to always refer to people living in mid-sized houses in sparse suburbs; lets not forget the many millions of people who live in dense urban spaces like apartment complexes. For me and most people I know, 2.4GHz is mostly useless and unusable due to the saturation of every channel thanks to the hundreds of wireless devices per-floor. 5GHz is the bare minimum to maintain a connection, and even that is more than 50% full. The 6GHz offered by Wifi 6E seems to be the real god-send; the sharper drop-off in range means that the network does not extend much further than the limits of your own apartment, so there is less chance of getting any overlap and crowding from your twenty neighbors' networks.
Internet speeds do not matter anymore. Verizon FiOS offers 300Mbps as the "base" speed for $40, and its plenty fast for most everything you need to do at home. And if you want 1Gbps, thats easily accessible too. The features that matter most these days are the enhancements to device<->router connectivity and connection stability.
WiFi analyzer. I have a few different versions on my phone though. There's also a desktop app I can get a lot more detail with called Acrylicwhich app is that?
True to an extent. My new phone has WIFI7 on board that was just released but, the lay man won't be looking at the intricacies of devices typically. Most just care if it has an Apple logo and stop thinking there. Network nerds dig a bit deeper and avoid Apple since they deem network advancement to be time wasting to them. They still sell AC only new devices and just now are putting in AX cards into some of their devices.Wifi 7 requires a new access point / router + client dedicated cards, because i can't think of many boards which have them built in.
They're coming sooner than you think if you're in the market anyway to pick up something new it's something to look for.1. There are not enough portables which can even support wifi 7 without new hardware, or replacing the portable entirely.
Depends on your setup. I get 1.5gbps out of mine and most non-nerds average 600mbps. If you pick the right HW on both sides it makes a difference.2. Its still SLOW compared to a direct ethernet connection.
It's already faster than 1GE and soon to be about 3GE with BE when the server side arrives i.e. AP / router. I would say that's better than most wired and even todays devices shipping with 2.5GE NIC options will be surpassed in the near future.3. Wifi will never be as reliable as a direct ethernet connection.
Sometimes you don't have the option to be wired with some devices and other devices don't have SD cards. Phones that are within the last couple of years don't have SD as an option for 99% of them. I would have to think hard and long to recall the last phone I had that had one. Funny enough my car systems do have them as an option for file management and I do use them occasionally to upgrade their software / maps / import music to the system.i would be a fool to transfer that much data from a portable
