Can U plz describe the wierd noise that U are talking about ... I mean, is it a constant noise or is it intermittent and what does it sound like ? ... As for the hot air coming out from the back of the case, this is normal as long as it is not that hot ... As a rule of thumb, U want cold air going in from front and bottom and hot air exiting from the top and back ... The noises could be 1 of a whole lot of things ... For all U know, it could be just the noise from the fan bearing ... Try cleaning out the fan with some compressed air and then power the rig up ... Just a basic step in the troubleshooting ... If noise still exists, then good way to find out would be to power up the puter with the case open, so that U can find out exactly where the noise is coming out from ... Then we can try to fix that ... Hope this helped ... Good Luck
