Wierd Video Problems
Reebdoog
Hi,
I'm having trouble with my drivers or something. I have a Dimension 3000, and I just installed a FX5200 pci. Its slower than expected, I'm only getting 20FPS in Call of Duty, this was what I was getting before the card. Anyway, for some reason, I can't uninstall the onboard video drivers, the computer keeps detecting it as new hardware when it starts up. And in device manager, it says I have 4 moniters! Please help
Here is a picture of what I see in device manager if that helps. And I have tried uninstalling the driver from add/remove programs, still reinstalls itself.
If you aren't using the onboard video, you'll need to disable it in bios, otherwise it will continue to keep re-detecting it..not quite sure how to get to the BIOS on a dell, but somebody should know..
EDIT: also, if for some reason you can't disable it in the BIOS, you could also disable it via the drivers, however it would still continue to use some of your ram that way. Just right click on it in device manager and click disable to do it that way.
what i did was disabled the drivers not uninstall them
also try drivercleaner to clear integrated video drivers
also it sounds like there is a proceesor or ram limitation if it doesnt get more
Hey this is driving me crazy
Whenever I disable the onboard from device manager I restart and it says found new hardware and it enables onboard again
PLEASE ANYONE HELP
what i think it should say is use video source or something
also press all F keys to see if you unlock more options in your bios
