Wierd SCSI problem
Kard
231
well its not really a problem, but some of my drives say "drive not ready" when i reboot and my scsi intereface initiallizes. By the time I get to windows they are fine.
only some of the drives do that, even ones that are the same brand/model.
Should I be concerned about this?
Thanks
Kard
Markfw
May 16, 2002
27,096
16,014
Don't worry about it. They just look a little longer to init.
mastertech01
Moderator Emeritus Elite Member
Nov 13, 1999
11,875
282
Ive only seen that problem on cold boots, usually doenst occur on hot reboots. Usually as Mark stated because the drives are slower to initialize than the system boots up with todays high speed systems. As long as they are working when you get into windows I wouldnt be concerned unless there is a termination problem and you get read/write errors.
