Wierd Problem With School Internet?
BChico
2,742
Well all of a sudden i am downloading at .3k instead of 400k. My room mates still get regular speed. Our school does have a limiter if you go over, im not in that though. Any ideas what would be causing this?
Thanks,
RemyCanad
1,849
Make sure you have a good patch cable. Also try connecting your computer through the connection your roommate is using.
Storm
3,952
Well if you abused your bandwidth you might be capped. Check your ethernet cable. Try bringing your computer over to your roomates ethernet port and plug it in and see what happens.
BChico
2,742
Ok ill check another jack, no im not capped we can check if we are.
