Wierd Problem: Sony CPD-G400 Monitor
yarone
Out of nowhere, my Sony CPD-G400 Monitor just will not work. I can't remember HOW it happened but no matter what I do now, it just displays "Monitor is in power saving mode." I've checked all documentation (and found nothing) and performed a self test (which succeeded).
I can connect my machine to my old NEC MultiSync and it works fine. No matter what I try, I cannot get a signal on my Sony. However, if i hold down the mouse-type button on my Sony for over 5 seconds, the monitor seems to ATTEMPT to display the signal which looks like a blurred out version of my desktop that flashes on and off the screen.
NOTE - even when booting up, the Sony does not show the DOS command line stuff - No signal at all.
Any ideas? I gave Sony support a brief stint, but after following the automated instructions, Sony tells me to contact my hardware manufacturers - and then HANGS UP!
Again, any ideas or suggestions? Thanks in advance. Note I've only had this monitor for a few days, and a problem like this is a real bummer!
.Yarone
Nope - made no new changes to machine - however, I will be recieving a Matrox G400 card soon, so we'll see if that takes care of the problem. But again, it seems like an issue with the monitor and not the vid card.
.Yarone
