TigerClaw27
I'm having a networking problem that occurs a few minutes to an hour after I boot up into windows. Usually I get dropped from the BF2 server I was playing on. Then if I try to ping a reliable server I get bogus results if ping.exe is running on core 0, if its running on core 1 it works. This is what i mean by bogus results:
Reply from 24.71.223.43: bytes=32 time=-59ms TTL=123
Reply from 24.71.223.43: bytes=32 time=-51ms TTL=123
Reply from 24.71.223.43: bytes=32 time=-54ms TTL=123
Reply from 24.71.223.43: bytes=32 time=-56ms TTL=123
Notice the negative time, but its not always negative, sometimes its +100 or +300 ms more then it should be (about 40ms is normal for me to this server). Now this happens wether i'm overclocking or not. Also I tried using another NIC, and the results are the same.
Anyone else run into a similar problem? Also are there any programs that test more then just the FPU (like prime95)?
I'm running an Opteron 165 on an Asus A8N-E, with 2GB of Kingston ValueRAM, and an FSP 400W supply (rails are very stable).
Thanks for reading this far,
TC
TC
