- Jul 26, 2007
- 397
- 0
- 0
Ok I'm building a mini gaming rig that I will ocassionally watch blue rays on. I've never bought a SSD before. I'm looking at
Kingston hyper x 120 gig for $129
http://www.newegg.com/Product/Produc...82E16820239045
And Intel x25 160 gig after rebate
http://www.tigerdirect.com/applicati...MobileOptOut=1
I know the Kingston is newer tech, but the Intel is cheaper and holds more. I've never messed with SSD's before. I will NOT be multi tasking. I will either playing a game or watching a blue ray and that's it. So would the Intel work for me or would I not even notice an improvement compared to western digital velociraptor? Or would i actually neeed the newer tech from the kingston? If I wouldn't see a difference in gaming between the Kingston and Intel I figured it be the way to go.
In this mini gaming system it will have an O.C.ed i3 530, and this ssd will be the only drive. I will be looking to put Windows 7 64 bit and a few games on it. Probably W.o.W., statcraft 2, diablo 3 and Skyrim. I can always swap games out from my small 500 gig Toshiba satellite if I need to. One last thing, the motherboard only has SATA 2 ports. Not sure if that makes a difference. Also, on games would I notice a difference between any ssd and W.D. velociraptor? Thank you very much for your help.
