Wich cooling solution do I need (please!!)
Kintoke
143
Well, I am buying a new Duron CPU (socket-a), 700mhz, but is OEM, so I have to put a good fan/heatsink combo to keep this thing cooled. The only problem is that I am tight of budget, so I need a good, decent cooling solution for cheap :). Also, I want to O/C my cpu to at least 800 or 850mhz. Please, tell me what thing do i have to buy?.
Thanks a lot
Mikewarrior2
7,132
A taisol cek733092 will suit you nicely. You can get it from Taisol Store.
or,
(gasp) a c-orb might suit your needs if you don't intend to overclock past 900mhz.
Mike
Jhhnn
IN MEMORIAM
Nov 11, 1999
62,365
14,684
Good choices, as might be the big blue Vantec from 2cooltek.com- $15+.
