why would my system reject 2x1024 supertalent ddr400?
ny_driver
54
It runs fine on 2x512 ballistix, but when I put in the other, windows boots and all, but after a few minutes I get the BSoD. Any suggestions. I thought maybe a bios update, but I looked and I have the current which is 1.D for MSI K8N Neo2 Platinum.
lopri
13,314
690
Sorry I closed your thread by accident and reponed it. As for the issue you're experiencing, you may want to loosen the memory timings or give slightly more (or less) voltages and see how it works.
wwswimming
Banned
Jan 21, 2006
3,695
i experienced something similar with the Intel 975XBX2 motherboard.
it had 2x1 GB. tried 2 x 2 GB. completely dead, would not do a thing. even though the XBX2 is specced as taking up to 8 GB, with 4 memory slots.
Ayah
2,512
Are you trying to run them at 1T? Your CPU won't like that. Did you try 2T?
aigomorla
21,077
3,577
Micron D9's have had some problems with boards.
Has to do with start up voltage.
Bump your voltage a bit higher then stock and see if u still have problems.
However micron D9's are notorious in dying fast if u over volt them, so try not to go too high.
mital
www.spielkonsolenkaufen.com
I am also faces the same kind of voltage problems. It is very hard for me to find it. I am also awaiting for the better type of suggestions from other people to make it everything good. This will definitely help me a lot to get the good suggestions from others. The voltage problem is definitely hard to find out. I think micron D9's are not working very well for me. Please give any suggestions for me to find it something better to work out.
faxon
2,109
which supertalent kit do you have ny driver. i have one kit of DDR 400 2x1 left and it's a C2 kit with part number X32PB2GC2 on the heat spreader. it mixed fine with the patriot, hynnx, samsung, and patriot ram it was mixed with at one time or another, but no micron stuff, which as aigomorla said, could be the problem. i was running this in an evga NF4 ultra SLI board (cant check the PN right now it's at a friends), and it mixed wonderfuly with many different kits on this board. i would say it's probably that micron D9 kicking it to ya lol
