- Sep 29, 2000
- 70,150
- 5
- 0
Two year old briggs and straton. It runs like a lion when it's running, but the only problem is that after a few weeks the carb clogs such that the primer bulb has no "grab" to it; no gas is shot around when you press it.
I once took the air filter off, poured a bit of gas in directly to the carb, started the mower, it died a few seconds later, but that cleaned the carb such that the primer then worked, so then I mowed the lawn without issue. This didn't work yesterday, so I soaked the entire carb overnight in gas and then shot tons of carb cleaner through it and this morning it's running like a champ, but I am concerned that it will clog up again! I am using fresh chevron w/ techron gas in it.
TIA
I suppose worse case I can spend 5 min each time I need to mow the lawn and take the carb off and clean it, but that sucks!
TIA
