why won't my geforce3 work?
perplexed
64
i got a gainward g3 3 weeks ago and installed it in my cusl2-c and could not get it to work properly.I followed the instructions,which i never had to read with any other tnt or geforce,as the install was a snap.After i installed this card it took several trys to get it to the point where you could change the settings of the card and when i changed them to 1024x768,first it said you have to restart for changes to take affect,which my geforce2 never does,and then when you reboot i get error messages saying the is not configered for the settings and puts it back to 16 colors 300x600,and no matter what drivers i use the same keeps happening.Now i have a visiontek card g3 and it does the same thing.I then loaded the card on my old bh6 with 600mhz piii and the same thing happened!!!!!!!!two different g3's on two different puters and i get the same results:disgust:Anybody had this problem??Any suggestions???????/Thanks
ps:Is the ecs k7s5a with ddr a great board for a gamer or is it a piece of s&it??I have read here and found both??
