- Jul 21, 2007
- 93
- 0
- 0
Alright I am getting to the point of wanting to abort the whole Trying to delete the RAID setup.
I am trying to get a Floppy disk drive to work on my Sig rig to install the RAID drivers on a Floppy disk to use to Re format the RAID Hard Drives.
My Sig Rig has never had a Floppy drive installed.
So I connected the Floppy Drive Ribbon to the MOBO, Now the thing I think is wrong here is which plug do I use to connect the Floppy drive. I have two plugs that will fit into the floppy, one has a P11 and the other has P15 on it. In my MOBO manual it does not say anywhere that I saw which plug to use to connect a floppy drive. So which one do I use?
I tried both, And the Drive doesn't seem to be working.
when I open 'My Computer' Tab from Windows it shows that the Floppy drive is connected. I went into properties and it says 'The device is working properly" which is a good sign. But when I go to put a disk in the floppy drive nothing happens. So I try to open it through the 'My computer' option, and it says, Please insert a disk into Drive a
Do I need to have a driver installed to get this Floppy drive to work?
I have never installed a floppy drive before so I need a little help please.
Once I get this Floppy drive working then I can put the RAID drivers on it and go from there.
Thanx
Thanx
