Originally posted by: Garet Jax
Thanks for all the responses.
Let me summarize to make sure I understand. The difference between a plain-jane LCD monitor and an LCD HDTV TV is the tuner.
More or less, but be careful. There is no rule that a TV advertised as a LCD HDTV must include a tuner. Check the detailed specs to confirm that it does.
In order for me to see HD content I need some sort of tuner. It can be an external box specific to the cable/sat company or it can be built into the TV.
Correct
If it is built in then I might be able to pick up OTA content.
Built in or if you have a external box (not from a service provider) then you can use an antenna to get OTA HDTV as long as your within 60 or 70 miles of a city with TV stations. The further out you are the better the antenna you'll need. If your in town you may be able to get away with rabbit ears
If it is an external box, then I can use an HDTV with or without a built in tuner.
Right again. And keep in mind that if your TV has a built in tuner you don't have to order the cable company's deluxe HD package & box because you'll get local channels in HDTV un-encrypted over the regular cable line
Is the tuner specific to the service provider? (ie. can I use the comcast tuner with another service or can I use the built in tuner with Comcast?)
Yes and no. Depends on the provider/box. Avoid the Voom boxes all over eBay because if the box isn't activated then you can't use it to get OTA HDTV
. Thanks.
