What about all the 64-bit PC's out there that have devices that don't have 64 bit drivers?
Just because 32bit can perform most of the times all the kinds of stuff that are required. So, why would anyone buy 64bit which is comparatively costly.
32-bit Windows could in theory still run 16-bit code (I say in theory because 32-bit Windows has always been capable of doing that, but I suspect that other changes to Windows probably has killed off most 16-bit apps). Think ageing applications made by companies that went under many years ago.
Or say a piece of custom-design diagnostics software which hasn't been updated to run properly on 64-bit Windows.
Microsoft in the past has placed Windows in a position suiting it for compatibility with older hardware/software. Whether that will still apply in the years to come with "the last version of Windows", I'm somewhat doubtful.
I'm a bit surprised that there's a 32-bit version of Windows 10 though (it would have seemed like a sensible time to draw the line). Perhaps purely because of MS offering free Windows upgrades for 7/8x users? I wonder if MS might still pull the plug on it at some point, given that for example nvidia has dropped 32-bit OS support.
Why? Because some companies still have 32bit processors and have a policy that they don't retire workstations until they die. These places still run XP and Vista, and if you have an app that requires Win7 or higher they will install it on a P4.
I see the above far more than 16bit needs.
Not everyone needs a modern computer to be productive. My boss uses xubuntu32bit on his machine, and it's sufficient for his needs. My work computer is xubuntu32bit cause the drive started in a netbook that had 2gb of ram I have no intention of upgrading. That machine can use use 64bit, but I would gain nothing for my purposes, so a reinstall would be a waste of time.I'm lost for words. You'd think they'd like their employees to actually be productive...
The most expensive component of a workstation is the person using it, after all.
Also because there are companies, that still use pieces of software, that were designed for windows 3.1, 95, and 98. For some they've moved onto newer software but might have an old database or function on that old software which can't be easily migrated or gotten. So they need a 32 bit operating system to run it.
For others it's more a matter of, they spent a ton of money back in the 90s for this custom software for their company, and by god they're going to use that software until the end of time. 😕
