Why not skip 64 bit and go right to 128+?
FeathersMcGraw
4,041
Originally posted by: hans007
a better idea, would be to destroy the x86 isa and start over with one that wasnt designed to save money and resources when everything was super expensive.
That's what Intel's Itanium engineers thought, except all the software developers and people with installed x86 software seem to think otherwise.
Beattie
1,774
Originally posted by: XZeroII
Why not just skip straight over to quantum computing? Or using neural nets?
Actual answer: because there are VERY few applications that will exceed the need for 64bits. The highest number that a 32bit processor can work with w/o software is 4,294,967,296. There are more people in the world than that. We need something bigger. A 64 bit comptuer can handle numbers as big as 1.84467440737e17. I don't think we will be needing numbers that big in our PC's for quite awhile.
I am sure people said something similar 10 years ago.
just like, "I will NEVER will up this 1 GIGABYTE hard drive!"
tcsenter
18,348
259
Why didn't we just skip the electronic communication age altogether and just go with mental telepathy?
her209
56,352
11
Because the instruction set is not that large yet therefore a lot of the bits will be unused.
glenn1
25,383
1,013
You know that in like 5 years everyone is going to be re-doing all the programs and stiff all over again just to support the new 128 bit processors. Why is so much effort going into 64 bit when they should be thinking ahead to bigger and better things?
Why not make an abacus with 1 million rows of sliding beads rather than a dozen or so? It may take a bit more wood (like a tree or two's worth) and be a bit bulky and heavy for most people to use, but you sure could calculate some hellacious math problems with it.
HokieESM
798
Actually, it was more like someone saying "I'll never use this KILOBYTE drive". There are eight orders of magnitude in the jump between MAXINT for 32-bit and 64-bit. We're still using gigabyte drives today (albeit 100s of megabytes).
64-bit computing is probably sufficient for a long, long time. Probably until some "new" technology reaches maturity, and we start doing base-3 operations or something silly along those lines. :)
spidey07
65,469
64 bit is nothing new.
Heck we max out 64 bit 8 way sparc machines all the time.
Its not that the technology isn't there, its that the devolpers are stupid.
Yes, the developers are stupid/ignorant and assume processing power is infinate.
jjyiz28
2,901
Originally posted by: Eli
Because that's not how it works. :p
8 > 16 > 32 > 128? :p
Since when has
8 been greater than 16?
8 been greater than 32?
8 been greater than 128?
16 been greater than 32?
16 been greater than 128?
32 been greater than 128?
Bah.. that's not what I meant... they're just arrows.
8 -> 16 -> 32 -> 128
Better? :p
Originally posted by: bleeb
Originally posted by: jfall
That is like saying people will eventually be using 5ghz processors, why not skip from 3ghz to 5
What comes after GHz? TeraHertz??
Yes.
MegaHertz, GigaHertz, TeraHertz, PetaHertz, ExaHertz...
MegaHertz, GigaHertz, TeraHertz, PetaHertz, ExaHertz, Zettahertz
beat u . =)
Spac3d
Banned
Jul 3, 2001
6,651
I don't even know how 64bit processors will benefit the normal user. I am guessing, it won't?
ElFenix
102,414
8,356
winnar!
KevinF
952
Since when has
Better? :p
Yes.
beat u . =)
MegaHertz, GigaHertz, TeraHertz, PetaHertz, ExaHertz, Zettahertz, Yottahertz
Beat you!
0roo0roo
64,862
84
actually it was more like bill gates wondering why u'd need more then 640k or ram :)
we need more mhz, not precision:p
