- Jul 10, 2007
- 12,041
- 3
- 0
the specification yes, but the physical medium itself is not maxed out, is it?
i'm using a very generalized argument but coax is copper and toslink is optical which allows for a lot more bandwidth, does it not?
I thought it was more of a rights management issue than a bandwith one.
In this case, the copper has more bandwidth. Remember the "fiber" in toslink is plastic![]()
Glass vs. plastic is not the issue. The issue that causes limits in bandwidth (and errors!) is the conversion on both ends. Remember a digital signal must be converted to light THEN on the receiving side it gets converted back to an electrical signal. With coax there is no conversion.
The use of higher quality transceivers and laser diodes would increase bandwidth and range tremendously. Optical SPDIF was never designed for this.
