Originally posted by: BlancoNino
Capital or lower-case W's are supposed to be drawn like U's and not V's...if your lines are straight, you're not making it correctly. double-u is correct.
Wrong. A "W" is supposed to be drawn just as it appears, two "V's" linked together, not two "U's". If you actually cared, you could search up some books that atually teach how to teach printing the letters.....they are geared for teachers to teach schoolkids like 1st graders. Each letter has a definite and assigned sequence of strokes per letter. A "W" is correctly drawn as it looks, as two "V" letters joined, with straight lines for each line, no curved "U" shapes at all.
I know because I remember my mom going through having to replicate the entire alphabet's proper sequence of letter forms for teaching while she was getting her master's in education. Dumb class made them completely replicate the entire alphabet and numbers 0-9 on a test, complete with each stroke and direction, and pencil lift and placement. Sort of like each letter with arrows and numbers along each line representing the first stroke and direction, then lift pencil, then place pencil for second stroke, then second stroke and direction, the lift pencil, then place pencil for third stroke, then third stroke with direction, and on and on ad nauseum........it was stupid, but they all had to do it.
So, there is a definite way to shape each letter and a "W" is two "V's" connected, not two "U's". And it's not because of typewriters, because as you can see, a typewriter correctly shapes a "U" without problem, so two "U's" wouldn't be any problem at all. They're not shaped like a "U" because they're not supposed to be.
