why is using a router with my home broadband connection good?
metallibloke
832
So i was talking with a colleague at work about broadband and stuff. This bloke is a networking guy but is cr@p at explaining stuff. Anyway, we got on to the subject of connecting several machines to the internet through a router. He said it would make the connection more secure, is this right? if so, what makes it more secure? would I still need a software firewall (currently run zonealarm). The router he recommended was a Linksys BEFSR41, 4-port whatnot. Link
As i dont know much about networking, except the basics, i thought i would pick the AT forums brains. Please posts any other info you think may be relevant, as i crave knowledge!
Thanks in advance.
(p.s. my ISP is NTL in the UK, if that makes any difference)
lucky9
557
The router has an IP address that is all someone/cracker on the internet can see. Most of the time, unless the government is after you, this will secure you from those on the internet that would be a bother. The software is to prevent something that you, on purpose, brought onto your PC. Both provide pretty tight security when used together. The '41 is a pretty fair one for consumer use. Linksys have an easy setup etc, be sure if you go this way that you use a strong password for the router. If physical security is not a problem you can paste it on the router itself. If the government wants you...don't put it on a computer.
PS: NAT (network address translation) and SPI (statefull packet inspection) are where you want to be with these things. It's where I'm at.
gunrunnerjohn
1,360
The reason for the added security of a router is the NAT layer. Unless you specifically configure ports to be forwarded to a machine on your LAN, all incoming requests are blocked. This is, in effect, an incoming firewall. There is no control of outgoing traffic, so the firewall protection of a broadband router isn't as complete as a good software firewall.
