In my house, I've set up a wireless-b network to share an internet connection amongst a couple of computers. It works wonderfully, except that it's quite a bit slower than it should be - both from a computer to the internet (and back), and just between computers on the network. Two of the systems are desktops, and the best speed I can get between them is right around 1 to 1.5 Mbps. If I try to download something from the internet, sometimes I can hit that speed; most of the time it's closer to half of that. Both of these computers are equipped with USB wireless cards.
The last computer is my laptop, which uses a PC-card type wireless card. On that, I can get almost the full 3Mbit/sec download speed from my internet connection. Transfering between computers I'm not so sure about, because I haven't done it in a while, but I suspect that it would be similar in speed to the transfer between the two desktops, unless I could get another PC-card or PCI-equipped machine in here.
Originally I thought that the USB 1.1 connections that the desktop "cards" use was the problem, but that shouldn't be it; USB 1.1 is rated at 11Mbps, correct? It shouldn't be overhead from using the encryption built into the router - that should slow things down a little, but if it were the problem, my laptop would be running at 1.5 Mbps too, I would think. I'm out of ideas. Anybody else have a suggestion? Here is a list of the equipment I'm using, if that would help at all:
EDIT: I should add - WinXP's little network monitor says connection strength is excellent, and is set to the full 11Mbps.
Router: Netgear MR814 v.2
USB cards: Netgear MA-111
PC-card: Linksys Instant Wireless WPC11 v.3
Nate
Nate
