Why is my steering wheel and shifter so stiff in sub-freezing temps?
psteng19
It's like 10 degrees F outside.
Car takes a split second longer to start, but gets going on the first try.
I wiggle the shifter and it feels like it's submerged in a bucket of thick maple syrup that's been in the fridge.
Steering wheel is near impossible to turn until the car gets moving for several hundred feet.
Gear oil, which is in your transmission, is quite thick. I would check your PS fluid, though. That should not be freezing up.
it's called an increase of viscosity because of cold temperatures.
I have never experienced that with PS fluid, though.
I wiggle the shifter and it feels like it's submerged in a transmission of thick gear oil that's been exposed to freezing temperatures.
Fixed
Switch to synthetics all around and you'll see less of this issue.
And it's not the PS fluid that's stiffening, it's the grease in the rack or steering box.
