- Dec 15, 2006
- 666
- 0
- 76
I have an Asus P6T SE and I have both my case fans running straight off the PSU with a 5V pin mod. I like it set up this way and have used this method for many, many computer builds.
I have always taken the single RPM lead of these fans (Vantec Stealth fans) and plugged them into two of the motherboard fan headers, one per fan, and was able to watch the RPM in the BIOS and in Everest, or any fan monitoring software.
But for some reason this Asus is picking up nothing for either fan. I've checked and rechecked and even double checked the fans on another computer, they are connected and are functioning perfectly in every other computer.
The Asus will pick up the RPM sensor just fine if you plug all three wires into a fan header so I know the P6T can read the RPM. Why does it need the power and ground connected? Is there anything I can do to retain my set up?
I didn't know if I should post this here or in the cooling section but since the issue seems to lie with the motherboard I figured this would be the best place to ask.
Thanks.
Thanks.
