Why is my burner's LED always on?
CasTroLTraN
I have a plextor PX-W4824TU 48X CDR-W burner. This burner originally comes from an external enclosure made by plextor. But since the USB 2.0 controller card from the enclosure died, I took it out and put it in my computer by using IDE. I don't know why but the burner's LED is always on (idle/green). There is nothing wrong with the burner, it burns and read just fine and is extremely quiet when on idle. It's currently set on a single channel by itself. But it does blink orange when it's burning and reading. I have never seen this burner being used in the enclosure before so I do not know if the green led was there before or not. Maybe this green LED is to tell that it's on idle??? Anyone have any clues? Thanks
I also keep a blank CDR in mine - and the small LED tells me it is ON. If I switch it off - the LED goes off. This is normal. The burn LED is a flashing LED - a bigger one in the middle. If I rem0ve the blank CDR - the little green LED stays on. Conclusion - it is the power on LED. 🙂
