why is it so hard to find small metric drill bits?
Aug 16, 2001
22,505
4
Damn, can't find those anywhere.
I go to SEARS and they've got plenty of metric threading kits, wrenches and other tools but no metric drill bits.
Where?
Nitemare
35,461
4
Where?
Look in Uranus, plenty of room to hide something up there...
1/10
Aug 16, 2001
22,505
4
Where?
1/10
This is not a parody thread. I need metric drill bits.
Nitemare
35,461
4
Where?
1/10
Harbor Freight?
Nitemare
35,461
4
No TrueValue here locally.
Lowes, Chase Pitkin, Home Depot?
Nope. They give me a blank stare when I ask.:confused:
Just get roughly the equivalent...
You are drilling a hole not like you have to be that precise...
Aug 16, 2001
22,505
4
Yes it has to be precise. The closest equivalent gives to much slop.
Aug 16, 2001
22,505
4
Originally posted by: QuitBanningMe
Is stepped ok?
What are you using them for?
I am making a 4mm bushing for my RC car. It's mod to take out slop in the suspention and I need to fit a 4 mm hinge pin in the bushing.
Stepped are not OK and the hobby store has none.
