Originally posted by: Denis54
Why is it better to have a rear than a front fan?
Like almost anything else involving PC component choices, the terms "best" and "better" are terrible criteria to attempt to use, because of personal subjectivity and differences in the box's designs, so "it depends" is where we end up. One of the most seriously considered reasons for fewer front fans being pre-mounted is simply the noise factor. But when various reasonably good case designs are taken into a lab for actual measurements, and a single fan is all that is used, other than the one in the PSU, many recently produced boxes with 120 mm front fan mounts begin showing excellent overall heat reduction results.
I'd love to offer a LINK for you, but I ran across this in a review of enclosures, very possibly right here at AT. (No, I don't think that's accurate, after all.) Wherever the site is, it is one on which different cases are compared, and a grid of heat zones are compared on numbered diagrams. As I recall, for enthusiasts with strong interests in Overclocking, the HSF's are getting better assistance from rear panel exhaust fans than from either front or side panel intake fans. However, once you already have a first fan as an exhaust, then a choice of front or side for intake may have to be made based on which of the two has the better intake flow path (few front intake mounts in low price cases are well designed, so the only intake is often a narrow lip slot at the bottom of the front bezel/ facia).
One of the most interesting results I have seen relatively recently is exactly how little value is obtained from an 80 mm fan in a top panel blow hole. I would think just from ordinary physics that rising air would already be collecting up near the top panel, in front of the PSU, but seemingly there isn't that much getting that far in most cases.
Geting back to my initial observation about subjectivity, in an environment where noise is critical to the results, such as a fan being used in an HTPC, the front fans are much harder for the enclosures to muffle sound from. My own personal choices, when limited to 80 mm mounts in oridinary enclosures, have been a single exhaust, whether or not twin mounts are offered, and a single side intake, located slightly closer to the VGA card than to the CPU, but in line with the CPU vertically (and this is a popular spot already pre-chosen on many of the windowed boxes).
