boomhower
I dropped the car off to get some oil leaks looked at and got the call. He was said it was leaking out the distibitor cap, valve cover, timing belt, and rear main seal. He mentioned the rear main seal was starting to go last time I was there when he did the master cylinder. Since they are already that far into the car you might as well go the water pump and the clutch. Now the bill is hitting $1000 bill. The car has !120K and seems to be in generally good condition, The tranny is a bit notchy but nothing horrific.
I guess the questions are:
1. Reasonable for all the listed parts to go out at roughly the same time?
2. Cost for the repairs sound reasonable?
3. The car has 120K on it, is it worth looking at a rebuilt motor, or a different vehicle all together at this point.
I am just trying get some ideas floating around before I make a decision tommarrow.
