Why is AMD CPU's max temp less than Intels?
bryanW1995
11,144
32
Thanks for the information. Like everyone else, I'll be digesting this.
One question: when I got into the OC hobby two years ago, AMD users were commenting that their CPU's began making mistakes when their temps got up into the high 50's. From this I concluded that they and Intel were using fundamentally different technology.
Does anyone else remember AMD chips making errors when they hit 57-60c? Or was I somehow reading the posts incorrectly? I 'll admit that a lot more went over my head then than now.
I routinely run my 1055t in the high 70's and crunch SETI 24/7 on that rig. I have had 0 error or invalid WU's since nov 25, and that one errored out on the GPU.
Don Karnage
2,865
It all comes down to (1) the physics that underlie reliability and product lifetime, and (2) the physics that underlie the power-consumption of the CPU.
1. Physics that underlie reliability and product lifetime:
Thermally activated processes (remember the Arrhenius equation from your p-chem classes) will approximately double in rate for every 10°C higher the operating temp.
A cpu at 70°C will have roughly twice the operating lifetime as a cpu operated at 80°C.
During the technology node development phase, getting the intrinsic reliability of operating lifetime of the process technology is a major challenge. Our here in the public domain you mostly hear about yields, but reliability is an equally challenging issue during those 4yrs in which the node is originally developed.
Well, what can you do if you are running out of R&D time, your node needs to be put into production asap, but the one thing holding it back is that in its current form (hypothetically speaking) your Lifetime Reliability department is telling you that the chips will die in about 12 months of they are operated at 100°C?
The easiest thing to do is to just limit the max upper-temp to a value that enables you to hit your reliability target. 12 months at 100°C is too little? No problem, at 90°C that 12 months becomes a 2 years, at 80°C it becomes 4 yrs, at 70°C it becomes 8 yrs.
Now if your customers can be convinced to restrict their operating environment such that the CPU doesn't exceed 70°C, and an 8yr expected lifetime conforms with your warranty model and internal targets (10yrs is actually the norm for the industry), then you could just go to production and not worry about the extra 6-8 months it would have taken you to get the intrinsic reliability of your process technology up to the point that you could expect an 8-10yr operating life at 100°C.
This is where/how Intel decides what TJMax is going to be. 98°C is based on how operating temps effect operating life, if 97°C was needed then that is what they would have spec'ed it at, or 99°C, etc.
By the way, it is this "reliability margin" that we OC'ers are using up and using to our advantage when overclocking.
A chip that is built with a process tech that can intrinsically support an estimated lifetime of 10yrs at 98°C means you get 20yrs at 88°C, or 40yrs at 78°C, or 80yrs at 68°C.
Well none of us OC'ers really care to have our 2600K's last 40yrs or 80yrs, so we in turn up our operating voltages (increasing voltage, any voltage, decrease lifespan of the CPU) to such an extent that we basically spend our reliability budget on increasing the Vcc.
"Hot Carrier Damage" kills the transistors by degrading them over time. This happens at any voltage, but more voltage (and more current) makes it happen even faster.
Checkout this short article for a very very cursory review of some of the issues at play in device reliability (TDDB, Hot Carrier Damage, Electromigration)
So that chip which could be expected to last 40yrs at 78°C with 1.3V might only last 10yrs at 78°C at 1.4V, and only 2.5yrs at 1.5V and 78°C.
Increase voltage AND keep your operating temps high(er) is just using up your reliability budget all the faster.
This is why OC'ers pursue lower operating temps (although they may not know why they are doing such)...its not just about the power-bill or the noise...and it is part of the reason why extreme OC'ers go to vapor-phase, LN2, and LHe temperatures before putting 1.8V and so on through their CPU's.
But at the end of the day the reason for the max temperature difference between AMD and Intel CPU's comes down to the intrinsic reliability of those CPU's with respect to thermally activated degredation mechanisms.
Intel spent more money/time/effort to improve the intrinsic reliability of their process integration at those nodes respectively.
2. Physics that underlie the power-consumption of the CPU:
The second reason why the temperature maximum need be specified is adherence to the TDP spec. Power consumption from leakage in the silicon device is fundamentally dependent on the operating temperature of the CPU.
All else held constant (Vcc, clockspeed, etc), a hotter CPU will consume more power than a cooler one (see this thread).
So if AMD wants to spec their CPU's as being 125W TDP, for example, at a give clockspeed and operating voltage, if the max temp is 100°C then they have to dial down the clockspeed and/or Vcc such that when the CPU is at 100C it is not violating its own TDP spec because of the elevated leakage current.
My 2600K has a TDP of 95W, at 98°C the chip is burning through about 45W of just leakage (static power consumption) losses alone, but if I drop the operating temps to 68°C then the leakage power drops to 30W. That gives me a 15W TDP "surplus" to raise my clockspeeds while not exceeding the spec'ed TDP.
So AMD, by lowering their max allowed operating temperature spec, makes it easier on themselves to hit their reliability spec's as well as making it easier to bin their chips for higher clockspeeds and/or Vcc's while fitting them into the desired TDP bins.
Talk about detailed...... Nice post
bononos
3,909
171
Well it still means that AMD is slicing it closer to the edge (from what I gather from the informative posts about temps).
Why does AMD stick the diode away from the core and keep the offset proprietary so that real cpu temps are unknown?
bryanW1995
11,144
32
Intel is usually pretty tight-lipped about the true offset temp as well. I remember all of our speculation back in the Q6600 days about what the real tjmax was for conroe and kentsfield. And they waited a year or 18 months to even let us know what it was. Regardless, the best way to use temperature monitoring software is to have it display distance to tjmax instead of absolute temperature. That way, tjmax could be 100, 1000, or eleventy billion and it wouldn't matter at all.
Magic Carpet
3,477
233
The thing is, my Deneb (965 BE) wasn't working reliably when it was routinely running in the 60-70c range. And it was the temp, not anything else. Once I installed an aftermarket cooler, all problems were gone. Sure as hell, Tjmax with Thuban is higher. I'm running it passively in the range of 70-80c with 0 issues. Although it does consume quite a bit of more power. 100% match with IDC's findings.
1) What pisses me off, is that they are both rated at 62c.
2) The single thermal diode in a six-core processor, which doesn't even show temperatures half-reliably. Shame on AMD.
My 10-year old Pentium 3 1400 Mhz runs at 65-75C still fine. Speaking of degradation. Kudos to Intel.
386DX
197
That was back in the Core days. With the current i processors the TJmax value for each chip is stored on the chip itself so temperature programs don't have to "guess" what the value is they can just read it from the register value on the chip. Regardless of how Intel handled the temp values in the past it's still better then what AMD has done and is doing now confusing there customers. You have to dig through the AMD whitepaper on there CPU's to even know the max temp value they rate there CPU at are not absolute values but some arbitrary value, yet temperature monitoring programs and end users keep thinking its the real temps.
I do agree with you that the absolute temperate isn't as important as the distance to TJmax. It's why I always find it funny when someone with an AMD CPU that's running at 58 C on load thinks there system is running cool. Max (diode value) temp for AMD CPU is usually 62 C or 71C so they are only 4-13 C from the thermal limit. On the other hand when someone with an Intel system is running at 73C everyone says its to hot... yet the typical TJMax value for Intel CPU is 105C, so at 73C they are still 32C from the thermal limit.
(sic)Klown12
572
Are you sure about that? My Phenom II reported per-core temperature in HWMonitor and other programs. Perhaps they use a single sensor and some sort of signal processing or other technique to estimate the temps in each core, though.
Some programs(some of the better reporting programs just list a single temp now because there is only one sensor) will report the single sensor's reading for each listed core. My best guess is that they re-poll the sensor the get a temp reading for each listed core, which is why you can see a slight variation due to the small amount of time it takes.
opethfan
16
My Asus board has a reading called CPU temp, which is usually around 10 - 15C hotter than the per core readings, and is what the Q Fan controller is based on.
For example; running P95 with a ambient of around 22C, CPU temp shows 59C, while per core shows 48C or so.
Idontcare
21,110
59
Yeah, my ASUS board has the same "feature", only in my case the reported CPU temp (using the ASUS software no less) is under-reporting the average core temps (as reported by realtemp) by a good 15-20C.
The way I finally figured out which one was right was to turn off the fans on my NH-D14 and run LinX until my 2600K started to throttle.
Sure enough, the cpu throttled right at 98C per Realtemp, which is exactly the TJmax where the chip is supposed to throttle according to Intel.
In that same run, according to ASUS software and whatever the CPU sensor was, my CPU never got hotter than about 80C.
Rifter
751
The AMD Hamster is not as fast as the Intel Hamster so it doesnt generate as much heat when running on the wheel so doesnt need as high of a limit.
Seriously though its because of the sensor posistion i believe.
Reactions: Magic Carpet
ocre
1,594
7
I really enjoyed this thread. Thanx guys for the informative and intellectual read. Its a ray of sunshine that breaks through the usual clouded muck.
