Why have four when running a base three?
jimmyj68
573
My cursory understanding of Nehalem processors is that they control memory on board the CPU in a three channel fashion i.e. three ram sticks - same size, voltage etc. It's easy to understand a board with six ram slots or three ram slots ---- what's up with a board with four ram slots????? How do you evenly divide a factor of three in four??? If one slot is to:confused: be always empty - why put it there?
PCTC2
3,892
33
It will still run in triple channel mode. Two sticks will run on their own channels, but the remaining two sticks will be in a flex-channel, both running on the same channel, sharing the bandwidth. It's for those who bought dual channel kits for older chipsets.
jimmyj68
573
Thanks for the reply PCTC2 - I got into a wrestling match with my wife's computer and didn't get back to you earlier - it's all explained in general hardware.
I know what you told me, but I don't understand. How would you arrange 6 gig of ram in four slots???? Unless you leave the four slot empty - are the boards designed to be OK with that? They do usually have the 4th slot a different color.:confused:
PCTC2
3,892
33
Yes. They are designed to have the odd colored slot empty. i7 is triple-channel and prefers sticks in multiples of 3. If you run 6GB, it is 100% okay to leave the 4th slot empty. i7 brings a new game to the table. Everyone is used to double channel with multiples of 2.
jimmyj68
573
ok so it looks like the board makers with 4 slots are just saving a few bucks on making the board. Thanks - now if I could only find a board that didn't have 3 pcie 16 slots;)
