traditionally tho the power switch circuit isn't meant to supply a steady current is it? if i'm getting what he's saying, there's one lead (2 pin) to both turn the system on and light up the power LED. the switch just makes contact long enough to complete the circuit and start the system, which is why you can use a screwdriver or a hdd jumper to start your pc. once you let off the switch the current is broken, so there's no longer a circuit and therefore no power to the led. i guess if both are wired parallel perhaps...
