Guess: Water is a polar molecule (it has a + side and a - side). While the molecules are electrically neutral on the whole, their polarity can make it seem like they are charged to the other nearby molecules and there is an attraction. Attraction = molecules are closer together = take up less space = higher density = weigh more.
Gallons into Pounds: Multiply the specific gravity of the liquid by 8.33* (weight in pounds of 1 gallon of water); then multiply this result by the number of gallons, to obtain the weight in pounds.
