Why does the GPU Usage when running Firestrike hover at 97-98% rather than 99%?
hsjj3
127
Previously on my GTX 960, I would get a constant 99% GPU Usage when running Firestrike.
Now though, on a GTX 1060, I see that it is instead maxing out at 97-98%. Sure, it's not a major difference, but nonetheless a difference exists and I would like to know why.
I looked at the CPU usage, and it doesn't seem to be an issue during the Graphics test for Firestrike. I have an i5 3330 and the CPU usage doesn't go much higher than 50%.
I also have a PCIE 3.0 x16 slot so doesn't look it should be losing out there.
Can anyone hazard a guess as to why this happens? Would be interesting to see if I can get it back to a constant 99% or not.
nathanddrews
Graphics Cards, CPU Moderator
Aug 9, 2016
965
534
www.youtube.com
I would say that if you had a mountain of granular data from both setups, it might be possible to identify the exact problem, but it could be anything from driver inefficiency on the new 1060 GPU to a very infrequent CPU bottleneck (driver related). Given the anecdotal evidence presented, 1-2% could very well be within the margin of error.
I assume that your Firestrike scores are significantly better though, right?
Bacon1
3,430
1,018
Overclock your CPU and test again. Just because overall usage is under x% doesn't mean its fast enough to keep up.
