- Dec 27, 2001
- 11,272
- 1
- 0
Originally posted by: hans030390
just a random though, if two cards using SLI are at different speeds (and i know they render half a screen) does one half go faster then the other in framerate?
Originally posted by: intogamer
its like memory and raid
Originally posted by: Heinrich
In this thread I was told that it was ok to run 2 different manufacturers as long as the hardware (dvi ports, tv-out) and BIOS were the same
http://forums.anandtech.com/messageview...&STARTPAGE=1&FTVAR_FORUMVIEWTMP=Linear
Originally posted by: ddogg
i guess it mainly has to do with different BIOSes on the 2 different cards. i want to see how ATI's multi VPU functions. i highly doubt though that they would be able to use different cards on it although i may be wrong!!
Only you get an 80% performance increase...
Originally posted by: trinibwoy
Sounds a lot more complicated than SLI with the need for a master and slave boards where the two are not interchangeable. But it will allow the use of different types of cards and may even need a dongle similar to Nvidia's little connector.
