Why does skin turn red when submersed in hot water?
icarus4586
219
I just stuck my hands under warm water, since it's cold at my house, and a thought struck me. Why do they turn red (or pink or whatever you want to call it) when submersed in hot or warm water? I know it's because of increased blood flow through the capillaries near the surface, but why does that happen?
All I could think of is that maybe the body does that when there's "free warmth," it tries to warm up blood from the external heat source without spending any of its energy.
Any other ideas?
Born2bwire
9,840
When the blood flows to the skin, you're actually decreasing your internal body temperature. This is what happens when you drink alcohol. You get a warm sensation from the blood flowing out to the skin but the overall effect is to actually reduce your body temperature. Generally, people take baths and showers with water around 100 degrees Fahrenheit. So for most warm liquids, you're going to be lower than your internal body temperature. And finally, if you are immersed in a liquid, then the mechanism for cooling via sweating will not work. From all of this, I would surmise that body is trying to cool itself in reaction to a high external temperature.
trend
603
I know a big (?) factor in why you feel colder when you drink is because alcohol opens up your pores.. more open pores = less body heat retained. :) doesn't answer your quesiton, but thought i would throw that out
Bassyhead
4,545
I don't drink, but I think it's the other way around. You feel warmer when more blood flows on the outsides of your body. There's a medical term for the effect the body has on regulating how much blood goes to the outsides of the body, can't remember it now. But, yeah, I would think that when you put parts of your body in liquids that are warmer than your internal body temperature, it will attempt to remove extra heat around those areas by diverting more blood.
TraumaRN
6,893
63
Thermoregulation and while I cant remember the term either but you are referring to blood shunting from the inner core of the body towards the extremities, your body will ALWAYS protect your core organs(brain heart liver etc) first before your extremities.
And to attempt to answer the OP's question. Your body is probably attempting to cool the water around you by opening up capillaries in your hand.....whether that's right or not I'm not sure, BUT it is your body compensating for the difference in temperature.
TraumaRN
6,893
63
Here are some helpful paragraphs that I've found for you
Heat Loss in Cold Water
In water, conduction is the greatest contributing factor to heat transfer. Water has a thermal conductivity about 26 times greater than that of air. This means that heat loss via conduction is 26 times faster in water than in air. With all variables considered, the body transfers heat about four times faster in water than it does in air of the same temperature. Humans can maintain a normal internal temperature when submerged in water when they remain inactive in temperatures down to about 89.6°F. When the water temperature is lower than this, the body becomes hypothermic at a rate directly proportional to the duration of their exposure of the thermal gradient [46, 53]. It is obvious that prolonged exposure to cold water can lead to extreme hypothermia and death. When submerged in water at 59°F, the body will experience a decrease in internal temperature of about 3.8°F per hour. If the water temperature was lowered to 39.2°F, internal temperature will decrease at a rate of 5.8°F per hour [55]. The rate of heat loss will be further accelerated if the water is moving, since this promotes the increase in convection. Survival time in cold water under these conditions is quite brief. Victims can become weak and lose consciousness within minutes.
If the metabolic rate of the individual is low, such as when at rest, even moderately cool water can induce severe hypothermia. Exercise in cold water increases metabolic rate, and can offset some of this heat loss. For example, heat loss increases in a swimmer moving at high speeds through cold water (due to convection); however, the swimmer?s accelerated rate of metabolic heat production easily compensates for the greater heat transfer into the external environment. When exercise ceases, the skin will cool rapidly, as well as the internal temperature.
Convection involves moving heat from one place to another by the motion of a gas or liquid across the heated surface. The air around us is in constant motion. As it circulates over the skin of an individual, it displaces the air molecules that have been warmed by their contact with the skin. The greater the movement of air (or liquid, such as water), the greater the amount of heat removal by convection. When convection is combined with conduction, convection can cause the body to gain heat in an already hot environment when the surroundings are hotter than the skin.
Not mentioned in the above excerpt is the role of the hypothalamus in thermoregulation. Sensory receptors, called thermoreceptors, are fine-tuned sensory machines that can detect changes in body temperature and instantly relay said messages to the hypothalamus gland. In response to the thermoreceptor?s incoming messages, the hypothalamus activates mechanisms that regulate internal body temperature. The hypothalamus has a type of internal memory bank where the optimal body temperature is stored. If this temperature has not been reached, the hypothalamus will act to see that it is. The smallest deviation from the optimal body temperature will trigger the thermoregulatory center of the hypothalamus to initiate these mechanisms.
Any changes in body temperature will be picked up by two different sets of thermoreceptors: central receptors and peripheral receptors. Central thermoreceptors are located within the hypothalamus, and are thus ?central? to the thermoregulatory system. Central thermoreceptors monitor the temperature of the blood as it circulates throughout the brain. The central receptors are sensitive to temperature changes as little as .018°F. Peripheral receptors are located in the skin. These receptors provide the hypothalamus and cerebral cortex with information about external temperature, thus allowing the individual to consciously perceive temperature so that the individual can voluntarily control exposure to heat and cold environments. During massive sweat evaporation, however, the skin can feel cold while the interior of the body is hyperthermic (overheated). In this case, the peripheral receptors would incorrectly notify the hypothalamus and cerebral cortex that the individual is cold, when in fact the body may be nearing a critically high temperature.
When body temperature fluctuates, it can be restored to normal levels via the actions of four effector mechanisms.
Sweat glands: When either the skin or the blood is heated above normal equilibrium levels, the hypothalamus will initiate impulses to the sweat glands, instructing them to actively secrete sweat that moistens the skin. The hotter the internal temperature, the more sweat is produced. Evaporation will take over once the sweat reaches the surface, as discussed earlier in this journal entry.
Smooth muscle around arterioles: When the skin or the blood is heated, the hypothalamus will not only send impulses to sweat glands, but also to smooth muscle tissue in the walls of the arterioles that supply the skin with blood, causing them to vasodilate (increase in diameter). This reaction will subsequently increase local blood flow to the skin. The blood carries heat from the deep interior of the body, and is more able to release that heat if blood flow to the surface of the skin is increased.
Skeletal muscle: When more body heat needs to be generated, skeletal muscle can be called into play. In a cold environment, the peripheral thermoreceptors will relay the signal to the hypothalamus. The central thermoreceptors will also notify the hypothalamus if blood temperature drops below normal. In response to this neural input, the hypothalamus activates the brain centers that control muscle tone. These centers will stimulate small and rapid neuromuscular reactions (shivering). This increased muscle activity will generate heat (as noted before, heat is a byproduct of the energy producing pathways).
Endocrine glands: The effects of several hormones can cause groups of cells to increase their metabolic rates. Increased metabolism affects heat balance because it also increases heat production. Cooling the body stimulates the release of thyroxine from the thyroid gland. Thyroxine can elevate the metabolic rate throughout the body by more than 100%. Catecholamines (such as epinephrine and norepinephrine) have the capacity to mimic and enhance the activity of the sympathetic nervous system. Thus, they can directly affect the metabolic rate of virtually all of the body?s cells.
Source:http://www.abcbodybuilding.com/magazine04/thermoregulation.htm
Not all of it is relevant to the topic but you get the idea. Enjoy and it does indirectly answer your question OP
icarus4586
219
Thanks all. That makes sense.
One other related question though. Why do the hands and lips, especially, turn bluish or purplish when you're swimming in cool (>20F below body temp) water? It doesn't really make sense that the body would divert deoxygenated blood to the skin, it seems like that would cause your body temperature to drop almost as much as having oxygenated blood diverted to near the surface of the skin.
edit: Maybe it's because your internal organs are getting the warmer red blood and your extremities are left with the blood that has less oxygen?
imported_blip
226
They don't turn blue because it's deoxygenated blood, they turn blue from a lack of blood flow. Your body will decrease blood flow to extremities (those parts furthest from your 'core') when in cold water, because it's trying to prevent heat loss through these areas. This is the same reason you'll turn this color after you die. When the blood stops flowing there, no more red color.
When you're too hot, more blood flow to the surface/extremities to remove excess heat = red color.
When you're too cold, just the opposite = blue color.
Xpage
459
15
www.riseofkingdoms.com
Alcohol dialates your capalleries, thus making them slightly bigger, allowing more heat to escape, thus the red face you get when you drink alot.
Same thing happens when you are hot, you release vasodialators which cause your capalleries to expand, same thing also happens when you get an infection (though the expansion of cappalerries allows macrophages to get intot he tissue to atatck the bacteria causing the infection.
When you are cold your capalleries decrease in size and less blood flows through them so you lose less heat.
Biochemistry for the win! My degrees have proven useful here
MrDudeMan
15,069
94
:thumbsup:
that is how the body protects itself. when you start getting dangerously cold, the body starts to shut off non-vital parts. the first thing you lose feeling in is your feet/hands, then your arms/legs/digestive system, and then conciousness and finally lungs/heart. it tries to keep the core systems alive and running to maintain your life basically.
also, when you get really cold, blood actually gets squeezed out of your vains and capillaries into the tissue. that is why people can die from being warmed up too rapidly. you have to heat them up slowly to allow the blood to be forced back into the blood stream from the tissue. if you warm them up too fast and dont allow the blood to get back in the stream, blood pressure drops and they can die. you can attempt to re-freeze the body to restrict the blood vessels again (to increase blood pressure), and then try to heat them up again.
