Why does saline solution exist instead of pure water?
JimmyEatWorld
2,007
With regard to medical use, why do they inject a saline solution when they could just inject pure water? What about the salty nature of the liquid make a difference? Andybody? it seems like its so simple that I'm missing it
Things I thought about:
1. The Saline raises the blood pressure more than water due to its density but still remains pallatable to the human body?
2. it helps regulate the Ph balance of the blood?
Help doctors and med students
notfred
38,241
4
Cause blood is salty, so they get the solution as close to the salinity of blood as possible.
ElFenix
102,407
8,595
blood is more akin to sea water than most things
IcemanJer
4,307
You're right on both accounts. The pH for pure water is just slightly off of the pH of our bodies, and would cause the cells to die if pure water gets into our blood stream.
dethman
10,263
because blood has electrolytes. so you need to inject a solution that has a similar concentration.
JimmyEatWorld
2,007
oh thats right!
plus it would also stop Amino Acids, cus the membranes would be incompatible between cells.
I think.
edit: who knows why I capitalized Amino Acids :eek:
tcsenter
18,953
575
With regard to medical use, why do they inject a saline solution when they could just inject pure water? What about the salty nature of the liquid make a difference? Andybody? it seems like its so simple that I'm missing it.
Well its not "intuitive", but it is simple.
Remember Molarity, Molality, and Normality? pH is a secondary consideration.
Viper GTS
38,107
433
Causing your cells to "die" would be an understatement, they would swell up like balloons & explode.
Google on cells in a hypotonic solution, you'll see.
One link for you
Viper GTS
Glitchny
5,679
it exsits to make the lives of people that use contacts annoying due to the fact that the stuff isnt like water, trying to clean it up makes it seem much more like oil, practially sticks to the counter, and if it hardens its cement.. so it has multiple uses
