Why does rotating a nearly dead battery revive it for a bit?
aphex
Moderator<br>All Things Apple
Moderator
Jul 19, 2001
38,572
Dead Remote.. Spin the batteries and you can usually get a little more juice... why is that?
d33pt
5,654
that's cause all the electrons point the same way after you rotate it.
NiteWulf
1,112
It's probably because the time it takes you to pull the batteries out and rotate them allows the chemicals in the battery to react with each other to produce a stronger charge. It's temporary because when you use the device again the charge falls back to unusable levels and the reaction can't keep up with the drain
