I was printing something off adobe acrobat, 4 pages, and the task manager said it took up 100 percent cpu, why is that? Is there something wrong with my system?(specs below) Windows Media Player was open as well.
Assuming it's parallel make sure you have print spooling turned on and check your BIOS to make sure you have the parallel port set to ECP+EEP (I think??).
