Why does power control settings on CCC keep resetting?
Aznboy1993
Whenever I try to set the power control settings under the overdrive tab in CCC it somehow always resets itself after a few minutes back to the default 0% after I set it to 20%. Why is this? (I am using MSI Afterburner 2.2.0 Beta 2 to overclock my unlocked 6950 to 960/1500).
I'm using Afterburner. I just have the power control settings setup in CCC b/c you can't do it in Afterburner. Is this a conflict of issue?
Because ATI/AMD are soo magical with their awesome ... cough cough drivers.
Now you have to do bunch of uninsatll and install blah blah. Let us know what happens.
I'm confused. You're using both CCC and MSI Afterburner for your settings? You have to use one or the other.
^above,
You should use one or the other.
And MSI afterburner can adjust voltage for cards if that what you need.
@Tweakboy,
Another *cough* drivers *cough* jibb? really >_<'
This isnt a driver issue <.<
And the uninstall + reinstall, isnt gonna help when its not driver related (its a user that doesnt know what their doing with the afterburner software).
Also.... nvidias drivers are so good?
Bumpgate? Starcraft 2 (menus) killing video cards drivers?
Early 590 drivers in the retail boxes for the 590 (without funktioning OCP)?
When was the last time, you remember hearing that AMD made a faulty driver that killed a video card?
^above,
@Tweakboy,
aight! ill just use msi afterburner than. is there a way i can increase power draw from the card? (the power control settings on CCC where you can increase it to 20%)..or rather, what does that option actually do?
http://www.anandtech.com/Show/Index...age=9&slug=amds-radeon-hd-6970-radeon-hd-6950
It determines at what wattage, your card throttles down.
So you can set the limit you want it to operate at, I believe.
Will it boost performance? only if you run into a situation where the card is useing more than your own set limit. There is a max of +20&#37; though... probably to stay within "ATX spec maximum".
I believe Anandtech mentions, only FurMark and Metro2033, are throttled down from Powertune at 0% (instead of +20%). And theres barely any noticeable effects in performance for Metro2033, so it mainly effects your "FurMark" performance.
(^ at stock clocks)
Exsample of how this "can" effect performance:
Crysis 6970 @200watts (-20%), 1920x1200 gives Anandtech 43.3 fps
Crysis 6970 @250watts (+0%), 1920x1200 gives Anandtech 51.5 fps
+20% wouldnt give anything extra here at stock clocks, because it doesnt hit the wall and throttle down in this game, from what I could make of Anandtechs artical.
PowerTune technology dynamically adjust the GPU core clock to keep the power draw within the TDP envelop. This is done on a frame basis, in other words PowerTune is a real time power draw management technology. PowerTune is implemented in the Cayman GPU.
As to why Afterburner turns off Powertune settings, when you use that, for overclocking? I have no idea.
Its a 3rd party tool though, its not something AMD made,... so for a "fix" you would probably need to get a MSI Afterburner version that supports it.
I found this thread:
http://www.overclock.net/ati/974870-hd-6950-power-control-msi-ab.html
found this User quote from thread:
Afterburner + PowerTune works fine on my unlocked Sapphire 6950
I restarted twice just to make sure the settings stuck on boot and they do.
I'm using Afterburner version 2.2.0 Beta 1
But I see your already useing "2.2.0 Beta 2" which should be a newer version... so I dont know.
KK thanks for the responses guys! It was the MSI Afterburner unofficial overclocking that caused the problem. I turned it off and everything was ok. But is there a way to go past 950 core without enabling unofficial overclocking? (Reason I ask is because I need the power control to be at +20&#37; or my card throttles)
