- Jul 6, 2000
- 344
- 0
- 0
...in their cordless phones with the "memory" problem of the NiCD batteries? Why does Panasonic continue to choose NiCD (Nickel Cadmium) over NiMH (Nickel Metal Hydride)?
Originally posted by: dman
It's not just panasonic, most companies still do. I have a feeling it's because the new batteries (packs) are highly profitable. $15 for a 3battery pack in a plasticwrap or $3 for the same batteries online in bulk...
I bought a vtech 2.4ghz set which does use nimh and they don't even use off the shelf batteries, they use some special 2xAAA set w/ a plug connector. So, if they go, I'll still have to buy a new pack or hack the one I have...
Originally posted by: Kevin
Originally posted by: dmanQ]
Those packs are like $10, its nothing to get crazy over...
But when they make 500%+ profit on them, it's a good reason NOT to switch to NiMH which last longer and don't have a bad problem w/ memory effect.
Originally posted by: amnesiac
...or Li-Ion which is even better.
Originally posted by: Cheese78CA
True, but there are cordless phones using Li-Ion batteries now?
sorry fellas, but LiIon is not better. They have to be replaced sooner than NiMH. which surprisingly would be a good reason for manufacturers to use them.
i like NiMH best myself.
Oops, yeah. Although lithium-ion cells withstand hundreds of charge/recharge cycles, the life of lithium cells is more limited than that of nickel-based designs.
NICD batteries have no more of a memory effect than NIMH batteries. The so called "memory effect" is a huge misconception that just keeps spreading. I'm too tired to get into the details but I've done extensive research on this. Also, IMO I like the fact that cordless phones use NICD batteries rather than NIMH batteries since NICD batteries weigh a lot less and still tend to last plenty long.
Don't forget those Polymers you hear very little about...
If it would be feasible, I wouldn't mind having those Lithium-ion Polymers in a cordless phone.
Well they cost a lot more than the other two types so do not expect to see them soon. Ni-Cd is bad for the environment so maybe if Panasonic was really concerned about the Kyoto effort, they'd use Ni-Mh.
Um, no. There is a real memory effect. NiMH batteries tend to give out a bit smoother of a powerband, too. I did all of this crap when I was into R/C cars, and I even tested the memory effect on an old 1500 mah NiCD pack. Although as mentioned above, R/C cars = using very very precise and expensive peak chargers.Originally posted by: MWink
Originally posted by: FishTankX
What i've heard is that with the proper charge (with reverse pulse whatyamacallit) memory effect can not only be stopped completly, but actually reversed! :Q
So if they use the correct charger, the impact of the memory effect will be so little it won't matter.
