Why does my windshield ice up when other cars don't?
BeeVo
1,076
I have 95 Honda Civic and my windows form ice like crazy. I come out in the morning and 2 cars sitting right next to it are clear and mine is iced up. I hate having to scrape them every morning. Anyone know why it would do this and other cars next to it wouldn't? Anything I can do or buy to make them not ice over as easy? Anything that will make the ice easier to scrape off?
BeeVo
1,076
Originally posted by: KnightBreed
Maybe they come home late at night and have only been home a couple hours?
No because this also happens with I go off with some friends and when we come back mine are iced up and my friends car isn't.
BeeVo
1,076
Also my neighbors live in my basement so I know they are home all night.
Krye
298
You could try buying some of that stuff that you put in windows that makes water run off easier. You could get a better ice scraper. You could always make someone else scrape off the ice for you! :D :D
IcemanJer
4,307
try one of those windshield polisher thingies that allows water and moisture to not stick onto the glass. you know, like RainAway and similar products.
BeeVo
1,076
Thanks for the suggestions, I will grab some next time I am at Walmart. Anyone else have any other suggestions?
Howard
47,982
10
Get your windshield a professionally-applied ITO (indium tin oxide) coat and the proper wiring, and you won't even care about the icing.
TubStain
935
get a whole bunch of clear cellophane and put it on your windshield before leaving your car at night. In the morning rip it off and stow it away. Repeat and you wont have to worry about ice :)
ok I havent tried that yet, but it seems like it would work.
Analog
12,755
that's a heater.
simms
8,211
what if the cellophane rips? then you'd have to start all over again :) snow isn't exactly light as... a feather.. (i mean, big bundles of it, like 1 foot on your car :p)
WileCoyote
694
they have stuff you can buy exactly for this.
its like a silvery mat (like a thermal matt you put beneath your sleeping bag) that you put on your front windshield
it works great, i used to have one.
EagleKeeper
Discussion Club Moderator<br>Elite Member
Staff member
Oct 30, 2000
42,589
Just take an old towel and pin it with the wiperblades.
Skel
6,218
679
Originally posted by: feralkid
Originally posted by: notfred
My car windshield doesn't ice up at all :)
Mine neither, but that's because my windshield is in southern Arizona.
I'm in AZ, and I sometimes have problems with ice in the mornings...
morkinva
3,656
Just a thought-- is it real hot in your car before you shut it off?
Try turning off your heater and cruising the last 2 blocks with the windows open
Howard
47,982
10
that's a heater.
If you call those defrosting lines on the rear window heaters, then yes. BTW, ITO is transparent.
WinkOsmosis
Banned
Sep 18, 2002
13,990
Yeah that way both the inside and the outside ice up.
