Why does my wifi connection sucks when the weather is hot?
Status
Not open for further replies.
vital
2,534
Everytime when the weather gets really hot, I keep getting really slow or dropped wifi connections. Anyone experience the same? Could it be my wifi router?
krotchy
1,942
Is your router itself getting hot or at least the room it is in? Some are definitely prone to to overheating and it could be your problem.
From a signal propagation standpoint there is do difference between cool weather and hot weather.
spidey07
65,469
Humidity refracts wifi, this gives less signal and more noise = slow or disconnect wifi.
31,958
Poor termination or contact somewhere expanding in the heat. I used to have the opposite problem where my connection would get worse as the temperature dropped but then improve dramatically when it rained.
TwiceOver
13,544
44
Same with all wireless signals. Humidity just sucks for wireless.
Summers at a WISP suck balls. Winters, thankfully, are great.
krotchy
1,942
The OP only mentioned heat not humidity, but that could definitely be the case since Water does a good job of absorbing 2.4GHZ signals.
A microwave works at 2.4 GHZ for a reason.
spidey07
65,469
Duh.
StinkyPinky
6,945
1,248
I always find the radio signal in my car is better during rain. Is that weird, or is there a reason for that?
Rubycon
Madame President
Aug 10, 2005
17,768
485
Higher humidity prevents static build up so reception is cleaner. Unless your receiver has an "S" meter you cannot determine if the signal is actually stronger.
Status
