Why does my while >0 go past 0 into negative numbers? in C
Onceler
1,262
Code:
#include <stdio.h>
int main ()
    FILE * pfile;
    unsigned long long bytesremaining =0;
    unsigned long long remain = 0;
    char name[150] = "";
    printf("enter the file name and path\n");
    gets(name);
    pfile = fopen (name,"rb");
    if (pfile==NULL)
        perror ("Error opening file");
    else
        fseeko64 (pfile, 0, SEEK_END);
        remain = ftello64 (pfile);
        bytesremaining=remain;
        printf(" bytes left =%I64d\n",bytesremaining);
        fclose (pfile);
        printf ("\nFile:\n%s\ncontains %I64d bytes:\n", name, remain);
        while (bytesremaining >0)
            printf("bytes remaining = %I64d\n" , bytesremaining);
            bytesremaining =bytesremaining-8;
        break;
    return 0;
thanks
Jaydip
3,691
21
Code:
#include <stdio.h>
int main ()
    FILE * pfile;
    char name[150] = &quot;&quot;;
    printf(&quot;enter the file name and path\n&quot;);
    gets(name);
    pfile = fopen (name,&quot;rb&quot;);
    if (pfile==NULL)
        perror (&quot;Error opening file&quot;);
    else
        printf(&quot; bytes left =%I64d\n&quot;,bytesremaining);
        fclose (pfile);
        printf (&quot;\nFile:\n%s\ncontains %I64d bytes:\n&quot;, name, remain);
            printf(&quot;bytes remaining = %I64d\n&quot; , bytesremaining);
        break;
    return 0;
thanks
Make bytesremaining signed.If a unsigned variableis assigned negative value in "C" it is converted to a positive integer.Just think it's very simple.
Tweak155
11,449
264
Geez C is looking more like Greek every time I come back to it. Unsigned long long? The insanity!
exdeath
13,679
10
You are subtracting more than is remaining and its wrapping to a positive unsigned int. What is the initial value of bytesremaining going into the loop? Probably not a multiple of 8. Sounds like you are trying to work in bytes and qwords at the same time, not sure why you are subtracting 8.
Step through it in a debugger and see for yourself.
Though I really don't see what that loop is accomplishing in the first place...
douglasb
3,157
As others have said, it's because you are using an unsigned type and your original bytesremaining value is not a multiple of 8. So suppose that its value is 3 and you subtract 8. Since it's unsigned, the sign bit gets ignored and it gets evaluated as 5 (instead of -5). 5 is greater than 0, so your loop continues when it should have stopped.
