- Jul 11, 2001
- 41,067
- 10,310
- 136
Drives me nuts. I got a new battery installed in my car a couple weeks ago by AAA affiliated local company. Seems to be fine. Using two multimeters, one a Triplett (bought online, around $50) the other Ames (bought from Harbor Freight, not one of their cheapies), either often says 0.00 volts DC.
The Ames MM has V as AC/DC, either. The other I set at 20volts DC max.
Sometimes they do show the voltage. I got one today to say 12.63v for a bit. Or it goes immediately to 0.00 again. I have tried moving the dial back and forth between detents, thinking some contact(s) aren't making a good connection. That's worked sometimes. The other day pulling out the leads and reinserting has fixed the problem. Today, neither fixed the issue. I'm pressing the probes onto the top of the battery posts, which are clean metal and with force, of course.
I have a Fluke MM but am afraid to even try it thinking it may affect the device, but I assume it would work.
Is it that the battery has too much power?
AI is no help.
AI is no help.
