why does my computer keep freezing
fusion5ny
57
this just started happening recently
it cant be a software problem since it froze once before windows even booted
asus probe readings are all ok
i ran disk error checking, so hard drive is ok
i thought it was the PS, but i replaced it and it was actually running ok for a little while but then after a few days started freezing again
asus deluxe 939 motherboard
athlon 64 3500+ 939 cpu
1.00GB of ram
windows xp pro sp2
someone help me, this is a fairly new computer so wtf
Remedy
3,981
which BIOS build do you have installed on your board? And, which brand or type of memory do you have installed? In which order do you have your PCI components installed?
Remedy
3,981
Originally posted by: fusion5ny
hard drive: Western Digital 120GB
psu: has the antec 430w, replaced it with the generic 500w that came with the z-alien case
here's the pic of the generic:
http://images10.newegg.com/productimage/11-105-107-11.JPG
motherboard: asus a8v deluxe 939
video card: nvidia 6800
bios: original bios that came with the board
memory: 2 sticks of 512mb corsair value select
The last BIOS update for that board is listed as June 6th. Is that what your board is using? If not, update it from here.
epsilon9090
144
THe first PSU might have jacked up some parts, which is why the Antec appears to have the same results. RMA everything and make a backup of your hardrive
fusion5ny
57
ha rma everything thats funny, i started off with the antec, not the original psu
ima try the bios update
