Why does my car drive "smoother" after I wash it?
grohl
2,849
Someone pointed this out to me and I laughed .. but over the years I swear its true... why?
:D
lxskllr
60,336
10,742
Define smoother. Other than placebo, you might have worn out rubber that makes it a bit smoother after washing. That's about it though.
Genx87
41,091
513
I would say it isnt driving smoother as much as it is driving quieter due to less dirt.
grohl
2,849
I know its in my head. Smoother, quieter, I don't know. I find it hilarious.
zinfamous
111,889
31,410
It also increases horsepower by about 10.
And remember to always inflate your tires to sidewall.
gaidensensei
Banned
May 31, 2003
2,851
Due to the aerodynamics of wind resistance and it's impact against small water particles, it acts similar as if it were an invisible chassis that is able to mend with the structure formed by the air molecules.
Thus in turn, less friction is produced. Friction from liquids is different from that of solid-gas impact. The water molecules begins by exerting a net drag on the car, and tends to give that "smoother" driving as you experienced.
Just kidding, that was totally made up. But I would imagine that water friction plays a minor role against air resistance until it's gone from the car.
FuzzyDunlop
3,260
12
maybe due to a build up of mud within the wheels. That gets washed out so that your wheels are no longer off balance.
dighn
22,820
4
it's cleaner so less friction. the performance enhancement is about 3.6x10^-19 but well within human perception.
13,851
Cleaning removes billions of forein particles on the suface, some of these have a higher static electricity reaction with the air then the surface of the vehicle. As air rushes by it creates a charge, causing the car to pull the air with it, all this air builds up and stays electrostaticly charged with the car, creating drag.
Evadman
Administrator Emeritus<br>Elite Member
Feb 18, 2001
30,990
You can get 10&#37; better gas mileage by dimpling your car like a golf ball.
SlitheryDee
17,252
19
The appreciative stares you imagine people are giving your car cause you to not notice the little bumps that are still present. Or you notice the bumps and rattles, but they are "clean car" bumps and rattles, which differ from "dirty car" bumps and rattles in no way other than being more acceptable to the driver. That is to say, you are not as critical of your car when it is clean, and therefore perceive it to drive smoother.
