Why does moving air feel cold?
Eli
Super Moderator | Elite Member
8
Originally posted by: HardcoreRobot
in a related note, if you are trying to cool yourself off by blowing air on yourself, make your mouth as narrow as possible. forcing the air through a smaller hole takes the heat out of the air. you can try it on your hand, if your mouth is open wide it is hot and sticky :)
also, i love this quote "friction causes the cold" hahahahahahahaha
Compression causes heat; squeezing air through a smaller hole would not cause it to lose heat.
It would increase the pressure though, possibly causing the illusion it is cooler, due to things already mentioned in this thread.
LongCoolMother
5,675
:D rub your hands together. it should get freezing cold!!
Nov 7, 2000
16,403
not an illusion, the air is colder
igowerf
7,697
How come every time someone asks a question like this, twenty people chime in with differing yet very confident answers?
LongCoolMother
5,675
i think most of us agreed. except for the statement about the friction :D.
biostud
19,731
6,808
Try to hold your arm into fast moving hot steam, then you will notice it does not feel cold.
Indolent
2,128
in more technical terms,
it increases the convection coefficient between your skin and the air.
Eli
8
No, it is not.
If you compress a gas, it gains heat, it does not lose it.
That probably isn't the best way to phrase it, but if we keep it in this context.. you know what I mean.
Howard
47,982
11
Originally posted by: LongCoolMother
wind causes moisture (sweat molecules) to evaporate. the change from liquid to gas takes energy, most of which comes from the heat on your skin.
No such thing as sweat molecules.
Howard
47,982
11
No, it is not.
I agree. If you compress a gas, the temperature will go up.
When you create a smaller aperture with your lips, the velocity of the air increases and evaporates water quicker. The faster the water on your skin evaporates, the cooler it feels.
BD2003
Its mostly evaporative cooling.
But dont forget to take into account that the vast majority of the time, air temp is lower than body temp (98.7), and the convection speeds up the cooling process.
