only 1 e6300 exists, from what i can tell.
Intel® Pentium® Processor E6300 - http://ark.intel.com/Product.aspx?id=41493
Intel® Core2 Duo Processor E6300 - http://ark.intel.com/Product.aspx?id=27248
To OP: I'm not sure why.
To confuse the customer into buying a more expensive CPU or one with higher profit margins.
To confuse the customer into buying a more expensive CPU or one with higher profit margins. Also, could be a combination of technical issues(Nvidia) and a desire to confuse the customer by muddying the waters.
The low and mid range Nvidia cards are a fluster clunk of renamed and rebadged architectures across 3 generations of GPUs now.
OK, I am going to thread-crap here. This is a troll thread and has no real purpose. Intel re-implemented the "Pentium" brand for low-end C2Ds a while back, and re-used this model #. Enough said.
Holy crap....you just used this thread to bash Intel and nV at the same time.
Let me guess.....you use AMD?
I have a better one for you..AMD coming out with X4 920 after the i7 920 came out. Could that be considered "muddying the waters"?
This.They used the same product number as they had for a different product from a different product line.
One is an EOL C2D (as already mentioned). The other is a still-available Pentium.
Pentium D 920, 930, 940, 950, 965
Intel Core i7 920, 930, 940, 950, 965
Core 2 Duo E6300
Pentium E6300
This.
The worst offender that I can remember of having confusing model numbers was the Athlon 64 X2 4600+, FIVE different processors sharing the exact same name.
Athlon 64 x2 4600+... Manchestor
Athlon 64 x2 4600+... Toledo
Athlon 64 x2 4600+... Windsor
Athlon 64 x2 4600+... Windsor EE
Athlon 64 x2 4600+... Brisbane
I remember debating whether I should get an Athlon 64 x2 4600+ vs an Athlon 64 x2 4600+ to replace my dead Athlon 64 x2 4600+. The former had a higher IPC while the latter offered more overclocking headroom. Alternatively I could replace my dead Athlon 64 x2 4600+ with another Athlon 64 x2 4600+ or I could even save some money and just drop in an old Athlon 64 x2 4600+. Since my motherboard was technically meant for the light power sipping properties of the Athlon 64 x2 4600+ I wasn't sure how well my motherboards power circutry could handle the Athlon 64 x2 4600+. In the end I went with the Athlon 64 x2 4600+ although I think I should have gone with an Athlon 64 x2 4600+ because I wasn't able to overclock very far on the Athlon 64 x2 4600+ I purchased due to said power problems.
That is actually a true story.
