Why does going to certain websites deactivate my WLAN?
JCE10
Whenever I go to certain websites or go to NPR to listen to their clips, my WLAN gets deactivated. I would have to run to the router and unplug it and replug it in to get it working again. Anyone smart enough to know of a fix?
Sooooooooooooooooooo frustrating.
because you touch yourself at night?
Seriously though there is no reason why it should on certain web sites. It is probably just loosing enough packets to the point at which it is deciding the connection is worthless, try turning off your 2.4 ghz phone (and your nieghbor's for that matter), also you might want to change the broadcast channel on the router.
Mine does that too. I have the 2Wire HomePortal from SBC Yahoo!. I will change the broadcast channel tomorrow.
